I make animations of technical stuff. I make hundreds of jegs by using cad. I then stitch together all these slides to make a movie. Yes I know I'm doing it the hard way but I'll stick with it i little longer.
I'm looking for a simple program that will:
stitch together all these frames
lengthen or shorten individual frames
allow me to make a subdirectory (like premier) for these frames or some other way to separate them. (ms moviemaker only dumps them in one place and this makes it very hard to work with)
Allow me to add subtitles AND PLACE THEM WHERE I WANT
this is a sample of my animations.
http://www.youtube.com/watch?v=eSPX5sjVYBc
My question is, will you help me choose a program that will help me edit these movies? I'm not after an animation programe (yet) I just want to join hundreds of jpegs together
I believe the combination VirtualDub and avisynth will allow to do what you need. Avisynth will allow you to take a single frame and turn it into a movie of various lengths. You can use a subtitle filter to add text, and the animate filter to scroll text, zoom in to portions of the frame and many other special effects.
Avisynth is a script based tool so you will have to learn some basic scripting avisynth, there are several visual editors for avisynth;AvsPmod, avsFilmCutter, and AVE Visual Editor. You can create a script use utilizing avisynth and one of these UI. Load the script in to virtualdub which will then create an avi file four you.
I like this approach when creating avi from a bunch of images as i don't have to create a hundred frame of the same image to create a 3 second clip of a still image. It's a bit of work but once you get the technique down it's a snap.Murphy's law taught me everything I know.
Open-source software to record video from webcam?
By kg123 in forum ComputerReplies: 30Last Post: 22nd Nov 2016, 20:15 -
Best open source NLE software
By landstake in forum EditingReplies: 42Last Post: 24th Jun 2012, 00:09 -
Open source video editing software for windows?
By metathran in forum EditingReplies: 2Last Post: 7th Mar 2010, 12:19 -
Do you donate to open source software?
By yoda313 in forum PollsReplies: 15Last Post: 28th Aug 2009, 19:15 -
open source remote access software?
By sdsumike619 in forum ComputerReplies: 10Last Post: 28th Jul 2008, 18:29
