Hi Maybe someone could help on this. I have an Asus Oplay media player that suits my needs fine. When I make any MKV with handbrake and then play it in the Asus, and hit the time skip button (jumps it forward by 1, 5, 10 minutes depending on setting), the video then plays at double speed and there is nothing I can do to get it to play at norma speed. But if I start the video playing then fast forward for a second, then hit the skip button, it's plays fine. I've noticed it only does this on Handbrake MKV's and not others. Any light you could shed on this would be great. Many Thanks in advance. Daz
Hey my friend,
I had the same issue with Asus O!Play, and Handbrake. Very simple fix to the problem. You must change the framerate setting from "same as source" to manually pick the framerate (eg. 29.97, 25, 24, etc...).
After I have done this, they all play back perfectly. When pressing the display(info) button on the Asus, the bad files would show as -1 framerate, but the new files do show to be at the proper framerate. -
Thanks for your help on this. I'll try your fix deadmeow and see how I go. Many thanks again. Daz
Any way to keep smooth mpeg2 playback with Handbrake?
By Forty0zFreedom in forum Newbie / General discussionsReplies: 11Last Post: 26th Apr 2012, 16:58 -
How do I convert video and make it play at double speed?
By OM2 in forum Newbie / General discussionsReplies: 7Last Post: 19th Mar 2012, 07:36 -
DVD Architect Studio 5.0 plays my files at double speed and no sound
By MCnDaHouse in forum Authoring (Blu-ray)Replies: 2Last Post: 3rd Feb 2012, 11:22 -
Handbrake playback codec?
By jfharper in forum Video ConversionReplies: 2Last Post: 8th Nov 2011, 20:52 -
Handbrake converted videos now 1/3 speed
By zelman in forum Video ConversionReplies: 5Last Post: 4th Mar 2010, 05:48
