Anyone can help me how can I pull out an embeded subtitle from *.mkv file? Is there any software or mechanism for that purpose?
Actually, the problem showed up when I tried to play *.mkv file with my mutimedia player (the device that has a hard drive and able to connect directly to my LCD TV and home theater set), but the embeded subtile to *.mkv file didn't show up. That's why I try to pull out the subtitle and make it as *.srt. Put the same name between *.mkv and *.srt, and I'm sure my multimedia player will be able to show the subtitle (*.srt). That's the whole idea and purpose.
Thank you...
	There are a lot of websites with free subtitles, subscene.com is my fav, you could just get them from there & edit.
	@Baldrick :
 Thank you very much. It works. I get *.sub and *.idx files. Can have the output as *.srt file? Can I convert *.sub and *.idx to *.srt ?
 @handyguy :
 I already search to those subtitle websites. None of them work properly. I have to inform you that my *.mkv file is Hindi Movie. So it's not that easy to have a proper subtitle for my *.mkv. Thanks anyway for your info
	Nope, you must manually convert the sub/idx to text with an ocr subtitle tool like subtitle edit.
  Subtitles get embeded in WMV when converting from MKV using Format FactoryBy PlayWithFire in forum Video ConversionReplies: 10Last Post: 12th Jul 2012, 11:22
  how to add a subtitle track file to an mkv file???By Sh@DY in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 20:57
  How to add subtitle into a MKV fileBy c1steady in forum SubtitleReplies: 2Last Post: 13th Nov 2009, 02:15
  how to split mkv file and subtitle file to play on blu ray via hdd usbBy julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:28
  extract subtitle from mkv fileBy py52126 in forum SubtitleReplies: 1Last Post: 4th Feb 2009, 18:01
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
