Hey guys!
I've been looking everywhere, but couldn't find anything so im begging for u to help. I would even pay for u guys. If anyone answers i'll love him forever.
So my problem is that how could i open a MPEG-2 TS Video (.TS) file in Sony Vegas Pro 8.0. Coz only the sound would load in.
THX so much if anyone could answer![]()
HDTVtoMPEG2 will repackage your video and audio from a .ts container into an .mpg container which Vegas should be able to work with. No encoding will take place, so your video will retain its original quality.
Thanks for the answer, but
when i try to "Add" it in HDTVtoMPEG2, it says: "Couldn't find a channel" -
There might be something peculiar about your specific transport stream, because vegas and hdtvtompeg2 should be able open "ordinary" transport streams
Try re-wrapping in tsmuxer into .m2ts , or try demuxing the elementary video with it -
Post the log from MediaInfo giving the details of this file which will help to determine the best program to sort your problem. As you have Vegas then the best strategy is to demux the TS file into elementary streams. As long as the video is not H264 then ProjectX in demux mode is the best way to go especially if you want to extract subtitles. A simpler progam to use would be MPEGStreamclip and you can either use it to demux or convert to MPEG2 PS format that Vegas will happily accept.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
http://www.kiva.org/about
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 04:46 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
Video/audio TS files convert to an uploadable MPEG video
By Prizm007 in forum Newbie / General discussionsReplies: 1Last Post: 4th Jul 2011, 15:30 -
How to convert just top/bot field of an interlaced mpeg-2 video to mpeg-1 ?
By vahid in forum Video ConversionReplies: 4Last Post: 19th Oct 2010, 03:26 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 09:52
