Hello Currently I ragarde to buy a BluRay DVD player.
Here are my criteria ... I want an all in one!
Blu-Ray Player, MKV, Divx, Divx HD ... Xvid ...
Lan (Wi-Fi can be but not required)
Important: I should be able to plug an external hard drive via the USB port, it must be formatted in NTFS (otherwise, no use for MKV because of the limitation of FAT32). I'd used a 2.5 inch harddisk without external power, only via USB.
Who can advise me?
thank you
Pacman2000
Do you care about region free playback? If you don't know what that means then you don't. But if you do care, you better say so now because we really don't want you to come back in a month crying about how your new player isn't region free and you can't make it region free. You'll get the standard "Should have checked before you bought it" answer in that case.
Asking for unpowered external hard disk support may be a deal breaker. They only chance you have of it working is if you have a small form factor disk drive. You're always better off with powered drives.
It might be good to know what country you live in as recommendations for Australia aren't going to be very useful to you if you live in Canada, for example. -
Hi
Thank's Jman98
Ok , i'm in Canada and i have a possibility to plug My Harddrive into AC power...
It's a good idee a possibility to open the region area i agree
Anabody have a model proposition
Thank's
Pacman2000 -
This would meet your needs, but it's a bit of overkill on the price.
http://www.oppodigital.com/blu-ray-bdp-93/blu-ray-BDP-93-Features.aspx
You will have to buy a 3rd party module to install yourself to make it region free. Or you can buy one from a reseller such as on Amazon who has already installed the module for you.
If price is a killer, Insignia makes some cheap models that are reported to be able to be made region free, but they don't support very many formats at all. Momitsu used to make more affordable region free BluRay players but they have abandoned the North American marketplace. There may be 1 or 2 other players that are sold in North America than can be made region free. Maybe others can post. Definitely do NOT buy Sony or Samsung or you can kiss region free goodbye, although they may do the other things you want.
My first bluray player
By zofi22 in forum DVD & Blu-ray PlayersReplies: 14Last Post: 17th Oct 2010, 09:43 -
DVD player: help to choose the right one
By Instant Martian in forum DVD & Blu-ray PlayersReplies: 0Last Post: 21st Jul 2010, 01:06 -
looking for a bluray player
By ricoman in forum Software PlayingReplies: 6Last Post: 3rd Nov 2009, 20:20 -
Bluray player in XP?
By bagmand22 in forum Blu-ray RippingReplies: 4Last Post: 21st Oct 2009, 06:59 -
What format should i choose for multimedia player markus 800
By Galdorf in forum Video ConversionReplies: 11Last Post: 20th Oct 2008, 14:35
