Alright when I open a movie with VD it doesn't display any picture at all. This just happened recently and I don't know what's going on. I don't know if it's my computer or VD and any helpful response is appreciated.
Thanx.
Try this:
Open VDub and go to options...display input (and output) video, and see if they are on (checked), or F9 and F10 wil do the same thing.As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Thanx for the help and it worked finally! But it won't display some Divx avis that I've downloaded from the net. They worked before but now they won't. Thanx for the help.
Which version of DivX are you using, and which version were you using when they played correctly?
I used to have version 4 and I updated it to version 5. In version 4 it would display all my avis. Now with 5 it would only display certain types.
Should I delete version 5 and reinstall version 4?
Why is Virtualdub doing this?
By skybooks in forum Video ConversionReplies: 4Last Post: 29th Jan 2011, 22:11 -
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Help with VirtualDub 1.9.7?
By hezbag in forum Video ConversionReplies: 4Last Post: 20th Oct 2009, 06:21 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
re: virtualDub
By merlie in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2007, 15:50
