Results 1 to 10 of 10
Graphic driver bug. Get the latest WHQL certified driver for your graphics chip.
If you have the latest drivers, go back a version or two.
Check temperatures.
Roughly how often, using some standardized form of time measurement, is "At times" ?
Remove card, reboot, shut down, replace card, re-install drivers.
Check the warranty on the card. Bad memory can cause this. -
@jagabo
@Nelson37
Rolled back, uninstalled, updated drivers, uninstalled card to no avail.
Temp is steady 100F, cleaned everything with compressed air.
Found that the problem always appears using Firefox.
Uninstalled FF and tried older and portable versions.
When 'Bookmarks' is clicked and if the list is so long that it overflows over the window the problem shows.
IE does not show the problem.
I Googled and found a few posts regarding FF and the annoyance - but no fix. -
firefox has a list of about 10.000 unfixed reported bugs, and not enough time to fix a tenth of them. they are more concerned with "new" version numbers rolling out these days to fix the old bugs.
I was using 6, regressed to 4 yesterday.
Both exhibited the condition.
Using 4 right now. -
I'm still of the opinion it's likely a graphics driver bug. I've seen similar problems in the past that were eventually cleaned up by a graphics driver update.
Trying to capture desktop running a screen magnifier
By Randy_the_Hack in forum Video Streaming DownloadingReplies: 1Last Post: 30th Jun 2011, 14:29 -
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 07:01 -
Capture Desktop screen on a streaming format?
By therock003 in forum Video Streaming DownloadingReplies: 4Last Post: 9th Feb 2009, 13:24 -
LCD Screen: video plays on desktop but appearing black on big screen...
By Heyjoojoo in forum Newbie / General discussionsReplies: 2Last Post: 23rd Jan 2009, 17:36 -
Defragment, re-arrange of fragments, and boot defragmenting?
By andy_blah in forum ComputerReplies: 3Last Post: 17th Aug 2008, 02:49
