    Jun 2011
    Miami, Fl
    1. I use Sony Vegas Movie Studio Platinum 10 and recently I transfered an old black and white 8 mm movie to DVD. The original 8 mm film is scratched, sometimes over or underexposed and therefore the DVD copy is likewise.I'd like to enhance it using the video software that I use. My first question is; are there any free plugs in that I can use with Sony Vegas to clean the video copy of this film and second, if I want to use a video FX to apply to a certain portion of the video only in order to correct the original exposure of the 8 mm film like brightness, contrast, etc how can I select the specific portion of the video and apply the effect to that portion only and not to the whole clip, because I think --and please correct me if I'm wrong--that if I drag the Fx effect to the clip, the effect will be applied to the whole lenght ot the clip. One more question; if I want to edit out a part of a video clip and I know that the part I want to remove starts at 00:00:00 and ends at 00:00:20, if there any way that I could use those figures to edit out that especific part?, like an editing feature in Sony Vegas where I can enter those figures and then remove those 20 seconds of video. If not, what video program does this? a professional one may be?
    Thank you all for your answers.
    http://www.blackmagic-design.com/products/davincirevival/
    Or Avisynth as second choice.
    Vegas is an editor -- wrong tool for restoring video.
  3. Member zoobie's Avatar
    Feb 2005
    Florida
    You simply zoom way into the timeline and split it where you wish. Then you can either mess with it or hit delete. It's a lot quicker to use editors if you study the keyboard shortcuts.
  4. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    Try Blender, it's free!
