Okay so I normally try download people who do Blu-Ray 720p and there's always the option of getting AAC 5.1 and AC3 5.1 which is better? Seems like the AC3 would seem so because it's usually close to 1 GB larger file than the AAC. And also how would you compare these to DTS? thanks
All 3 are lossy audio compression formats. AAC is what Apple standardized on and you see it used mostly because Apple devices like it, although I think there may be some European TV broadcast support for it too (not sure on that). AC3 works just about everywhere so it's a good choice if you want to be sure your playback device will work with it. DTS produces a louder sound than other formats and tests have shown that humans will perceive a louder sound as being of higher quality than a softer sound of the same thing. DTS throws away some upper frequencies to compress its audio. Many people swear by it, but we've had a few industry insiders post here about the truth behind it. They're sworn to secrecy because of non-disclosure agreements, but they have strongly hinted that DTS may actually be a lot less faithful to the original sound than most people realize. Honestly they're all pretty good but DTS would typically take up the most space.
Difference Between DTS 5.1 & Dolby Digital AC3 5.1
By dorababu in forum AudioReplies: 8Last Post: 31st Mar 2013, 22:31 -
MeGUI audio encoding dts/ac3 to aac-mp4, keep getting errors
By runLoganrun in forum AudioReplies: 5Last Post: 29th Jul 2010, 18:15 -
Convert h.264 MP4 w/AAC 5.1 audio to AVI file w/AC3 5.1 audio for Xbox 360
By ycrazyy in forum Newbie / General discussionsReplies: 6Last Post: 14th Jan 2010, 16:25 -
demux audio from avi then two audio sources(aac 2ch + ac3 6ch)
By fatcat23 in forum ffmpegX general discussionReplies: 4Last Post: 21st Sep 2008, 02:19 -
Audio converter for AAC, AC3 and OGG
By MasterRoshi in forum Newbie / General discussionsReplies: 12Last Post: 20th Feb 2008, 17:54
