Using the latest version 3.2.x Pro, ripping the english version of PAUL from DVD results in a movies with several scenes where the scene is repeated for like 5 to 10 seconds. It is also possible that it skipped a few scenes, but I haven't gone back to watch the ISO image to be sure. I've seen this on several other discs in the past as well, but 3.2 fixed those (repomen). Any ideas?
This first was noticed on PAUL. It has now also happened on YOUR HIGHNESS. Apparently, when a disc has both a rated and unrated version, without being entirely separated streams, but share most of the streams, and have only minor play list differences, VOB2MPG PRO is picking up BOTH versions in the output. This is a serious BUG, because it makes the rips of newer movies completely worthless.
If you decrypted only the version you wanted in the first place, before then using VOB2MPG, this wouldn't happen.
I do see that it claims to be able to handle angles so maybe it does have a problem, but decrypting just the version you want will still prevent the problem you're having.
Repeated burning error with dvd flick :(
By Akhet in forum Newbie / General discussionsReplies: 24Last Post: 6th Apr 2016, 09:45 -
Ripping my DVDs, taking out scenes and joining them
By theofile in forum DVD RippingReplies: 1Last Post: 9th Mar 2010, 16:14 -
Creating a DVD menu pattern for repeated use
By pbear23 in forum Authoring (DVD)Replies: 1Last Post: 5th Mar 2009, 04:34 -
question about repeated DVD burn failure at about 90%
By jimdagys in forum Newbie / General discussionsReplies: 18Last Post: 18th Mar 2008, 22:34 -
DVD Ripping and Missing Scenes
By dimpayne in forum Newbie / General discussionsReplies: 11Last Post: 6th Dec 2007, 13:24
