Hi everybody, I'd like to know if there is any way how to convert mkv file containing špgs subtitles(in .sup format) to m2ts. I've tried tsmuxer but it doesnt support .sup subtitles in mkv container, only srt. I have wd tv live player and it doesnt support pgs subtitles which are in mkv, but if they are within m2ts, it plays fine. Is there any software to handle this? Or i have to demux first then convert to srt and remux again?? thx for advice
edit: sorry, it is PGS no PSG in topic name![]()
Tried extract the sup pgs subtitle with mkvextractgui2 first? Then add it and the mkv in tsmuxer and make a m2ts.
I use BDSup2Sub in the process of backing up BD to MKV, using ClownBD, http://www.mediasmartserver.net/2010/03/31/mkv-mania-clown_bd-mkvmerge/ .
So you get that Sup out from MKV change it to Sub/Idx using BDSup2Sub (it takes couple of seconds) and mux it to MKV again. That tutorial will tell you exactly what to do. It works, I have WDTV Live plus myself. -
Bump !
Hi guys ! Regarding the neat process up there involving BDsup2sub => MKVMerge, I must be doing something wrong.
I do indeed have my PSG converted to NAME.idx + NAME.sub, problem is when importing the idx into MKVMerge the sub doesn't follow. That is, the .idx is imported but when I mux the subtitles aren't there in the output file. VLC detects a subtitle track, but nothing shows.
To further test my file, I tried to manually open the idx and / or sub file in, say, VLC, after having launched the video. Then the subs play correctly, so the idx and sub files created by BDsup2sub are fine.
Any thoughts ?
Thank y'all ! -
Have you confirmed the subtitles aren't muxed into the MKV by other means (aside from VLC)? For example, by opening the MKV with MKVMergeGUI for a look, or checking the MKV with MediaInfo. Or even try a different player such as MPC-HC. Just to make sure it's not a VLC issue......
You could also try extracting the subtitles from the MKV with gMKVExtractGUI or MKVCleaver. If the extracted subtitles are very close to the same file size as the original, they probably should be okay. -
.M2TS to .MKV
By cjbrown80 in forum Video ConversionReplies: 2Last Post: 18th Aug 2011, 21:34 -
mkv or m2ts
By kcmccombs in forum Newbie / General discussionsReplies: 9Last Post: 21st Jul 2011, 04:25 -
Remuxed M2TS to MKV gives PGS subtitles without language flag (with Blurip)
By Quasit in forum Video ConversionReplies: 1Last Post: 30th Nov 2010, 13:31 -
Blu-ray backup/playback problems (mkv, m2ts, ffdshow, mkv splitter)
By Pyrophoric in forum Video ConversionReplies: 0Last Post: 3rd Mar 2010, 11:26 -
M2TS to MKV
By mblanco2000 in forum Video ConversionReplies: 4Last Post: 11th Feb 2010, 13:27
