Does anyone have like hundreds of movies ripped to external hard drive?
Looking for something so when i go on vacation, i can take and connect to friends'
Media Server and have all my movies....
Yes, you may rip your DVDs to an external HD and, assuming you have the appropriate player on the other end (your friend's Media Server for example), it should plug right in and be available for play.
I use a WDTV player and this is how I do it. -
the trick would really be to have your library sitting at home on your lan and have a good enough network connection so that you could stream your movies over the internet .... perfectly doable iif the connection is stable enough and the bitrate is not too high.
HINT uncompressed blu rays may not work!Corned beef is now made to a higher standard than at any time in history.
There was some goof here that had all his movies on internal HDDs for some reason...
VIDEO_TS/External Hard Drive
By Blotttt in forum Newbie / General discussionsReplies: 1Last Post: 8th Feb 2010, 18:26 -
external hard drive
By alintatoc in forum ComputerReplies: 20Last Post: 26th Sep 2009, 20:54 -
Adding external hard drive
By didikai in forum Newbie / General discussionsReplies: 22Last Post: 14th May 2008, 03:07 -
External Hard Drive > TV?
By jason in forum Newbie / General discussionsReplies: 36Last Post: 12th Mar 2008, 10:32 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 09:47
