  1. I am having troubles with HdBrStreamExtractor. When I click features nothing displays. There is nothing in the features and stream(s) windows. At the very bottom it says \stream" [17:08:04]Feature retrieval completed. I have tried selecting both input folder and file and get the same issues. I have .net framework 4.0 and haali matroska splitter installed and have the lastest versions of eac3to v3.24 and HdBrStreamExtractor v0.8 installed.
    if it wont work you can try clownbd.
  3. I tried using clownbd and got nowhere, perhaps tutorial would help me. I like using HdBrStreamExtractor but why wont it work. HdBrStreamExtractor worked before I did a fresh install of my OS.
  4. I found out how to use clownbd.
    Thanks.
