    May 2009
    Well...I know ripping the audio directly from DVD is absolutely possible and is not hard to do...All we need is a proper software. Then we could demux it or convert the audio of the DVD to any format we want...
    However, the problem is how we can make it a CD with selection of the audio tracks just like regular CD.
    Here is the question.
    I have a karaoke show DVD...you know like the singer singing on stage. However I would like to rip only the audio from the DVD and then turn the whole audio into a selected audio like what we have on the CD that you could skip a track or move to the next track...Is it possible to do that?
    kenryuakuma always need your help
    DVD audio extractor can break by chapters.
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    DVDDecrypter can rip by chapter and demux audio from video(also give you each individual chapter with just the audio)....that's IF your karaoke DVD is a normal video DVD with a VIDEO_TS folder.
    May 2009
    Thanks and I will try that.
