My DVR-433 is locked.Every taste I press on recorder, on display appear LOCK.
I disconnect recorder from the mains, but no help. What is wrong?
Someone activated the child lock option by mistake. To unlock the recorder, you should reconnect the power to the recorder. Press and hold down the black stop button on the recorder (not the one on the remote control) for three seconds until the word UNLOCK appears on the display. I know this works on a DVR-533H-S recorder.
I connect recorder after more than 5 days. On display appears --:--. After set up all working. But after some time again LOCK and after few second UNLOCK appear on display. I reset my recorder (press and hold black stop button and press standby/on buton). Again --:-- on display. After set up recorder work, but again LOCK and UNLOCK appear on display several times. What next? Maybe replace all electrolytic capacitors (19) on PSU board?
Unfortunately, I cannot explain why LOCK and UNLOCK re-appear again. Maybe send a private message to Hkan, one of the members here. He's the expert on servicing Pioneer recorders.
Here's one of Hkan's posts:
https://forum.videohelp.com/threads/196949-Hard-Drive-upgrade-for-Pioneer-DVR-520H?p=20...=1#post2035178
edit:
If you had another DVR-433 to take apart, I probably would swap the front control panel and see if that fixes the problem. Could be a dirty contact on the black stop button or a faulty control panel. No guarantee however.Last edited by em-t-wallitt; 28th Aug 2011 at 14:16. Reason: suggestion to fix the recorder and link to Hkan
Pioneer DVR-520H: seeking advice for DVR-107-XA drive replacement.
By donglejack in forum DVD & Blu-ray RecordersReplies: 71Last Post: 12th Feb 2012, 09:24 -
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 20:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Replace Pioneer DVR-104 with DVR-115D? EIDE cable the same? Other questions
By Goldenvoice in forum DVD & Blu-ray WritersReplies: 1Last Post: 13th May 2008, 08:20 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02
