I bought Apples QuickTime MPEG-2 Playback Component for Windows and also installed http://www.squared5.com/svideo/mpeg-streamclip-win.html and it seems to be working well chopping up my m2v files.
note: what I want is zero re-compression if possible, I just want to chop up my footage and export small clips with the least amount of impact on the quality as possible.
what i did so far was set the in and out point and then chose "demux to m2v" . the result look like its perfect but am i doing something wrong? is there a better way?
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Using HJ Split
By jyeh74 in forum Newbie / General discussionsReplies: 4Last Post: 17th Mar 2009, 00:59 -
VobBlanker DVD Split- Automatically jump to Split Title
By src2206 in forum DVD RippingReplies: 12Last Post: 11th Dec 2008, 07:58 -
Split Mpeg or convert to AVI then split. What to do?
By oldfart13 in forum Video ConversionReplies: 4Last Post: 24th Mar 2008, 00:00 -
Procoder split/split by size/media query
By kippard in forum Authoring (DVD)Replies: 7Last Post: 17th Nov 2007, 22:35
