I want to backup a Dual Layer DVD to XViD. The DVD running time is around two and a half hours so I'd expect my output would be two 700mb avi files. I haven't been here in years. When I was last here AutoGK was the program of choice. I've just tried their website and it seems to be down so I'm wondering is it still the best and simplest? I'd appreciate any feedback! Thanks guys!![]()
If you want xVID then autogk is the simplest. Has not been updated for years so maybe the author's site is down for good. But you can still get it by direct download from this site - just follow the link you created in your own post( or even the one in this reply).
But xVID is no longer the standard unless you really need to play your conversion on your dvd player. H264 and mkv will give better quality/compression than xVID.
So take a look at the forum for some more info. Quite a bit has changed in the last few years.
VirtualDub/Xvid question: YV12 vs. XVID FourCC in the xvidvfw.dll driver???
By KneeRow in forum Video ConversionReplies: 14Last Post: 1st Aug 2010, 14:35 -
Does xvid cli (command line version of xvid) actually exist ?
By vhelp in forum ProgrammingReplies: 10Last Post: 29th Oct 2009, 15:18 -
help combining 2 xvid avis and 2 subtitles (srt) to 1 xvid avi
By hibbs in forum SubtitleReplies: 4Last Post: 14th Jun 2009, 20:05 -
How to encode an xvid file to another xvid and prevent video blocking?
By BlooderButcher in forum Video ConversionReplies: 5Last Post: 21st Nov 2008, 17:03 -
Weird I don't have XviD or DivX codec installed but I can see Xvid movies
By Talayero in forum Software PlayingReplies: 4Last Post: 5th Jun 2008, 12:47
