I received and downloaded a video file sent to me in the following configuration-
video.avi(1).asx 97MB
video.avi(2).asx 97MB
video.avi(3).asx 83MB
video.avi.asx 97MB
I can get the video.avi.asx to open in VLC but it only plays for 10 minutes and stops. Is there a way to join these files together or get the other components to play? Many thanks!
	You could try a binary joiner like http://www.jaist.ac.jp/~hoangle/filesj/ first.
 If it fails then are they avi or asf files? Use mediainfo to identify.
	Ok I sorted it.
 I took the following--
 video.avi(1).asx
 video.avi(2).asx
 video.avi(3).asx
 video.avi.asx
 and renamed them as follows--
 video.avi(1).rar.002
 video.avi(2).rar.003
 video.avi(3).rar.004
 video.avi.rar.001
 and then played the files with VLC media player!
 Now please see my Sound Forge thread in this same subforum. That one still has me befuddled!!Last edited by mjl1297; 27th Aug 2011 at 04:39.
	@AlanHK not to seem thick but would you mind illustrating your point, i.e. rename the files in my example the way you mean?
	Often the wrong suffix on a filename confuses software. So if they're really avi, try naming your files
 video.avi(1).asx
 video.avi(2).asx
 video.avi(3).asx
 video.avi.asx
 as
 video1.avi
 video2.avi
 video3.avi
 video.avi
 and try opening them in Avidemux then.
 The .001, .002, etc you used indicates to VLC that they should be played in sequence, the rar part is not helpful but fortunately is ignored. VLC isn't so easily fooled.
  Playing ASX or other online broadcasts on Sony BDP-BX57By big_bang in forum DVD & Blu-ray PlayersReplies: 0Last Post: 7th Jul 2011, 03:07
  ASX and ActiveMovie WindowBy LTLTI in forum Video Streaming DownloadingReplies: 0Last Post: 30th Sep 2010, 16:29
  How to play asx files when inernet is offline ?By cdstoke in forum User guidesReplies: 5Last Post: 27th Jan 2010, 11:46
  question about how to use cue file to break big audio file into tracksBy jimdagys in forum AudioReplies: 13Last Post: 12th Oct 2007, 09:40
  Creating a .asx batch fileBy azpuma in forum Newbie / General discussionsReplies: 0Last Post: 3rd Sep 2007, 12:18
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
