    Mar 2004
    San Diego, CA
    I have 2 MP4 files that have AAC audio. Problem is my WDTV LP can handle it, but my receiver does not
    (Kenwood V-407)
    Is there any way I can replace the AAC with AC3 (hopefully keeping all channels) without having to change the video in any way ?
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 1.50 GiB
    Duration : 1h 40mn
    Overall bit rate : 2 125 Kbps
    Video #1
    Format : AVC
    Format profile : High@L4.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 8 frames
    Codec ID : avc1
    Duration : 1h 40mn
    Bit rate mode : Variable
    Bit rate : 1 800 Kbps
    Maximum bit rate : 9 499 Kbps
    Width : 1 280 pixels
    Height : 528 pixels
    Display aspect ratio : 2.424
    Frame rate mode : Constant
    Frame rate : 23.976 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.111
    Stream size : 1.27 GiB (85%)
    Writing library : x264 core 92 r1510 33d382a
    Audio #2
    Format : AAC
    Format version : Version 4
    Format profile : LC
    Format settings, SBR : No
    Codec ID : 40
    Duration : 1h 40mn
    Bit rate : 323 Kbps
    Maximum bit rate : 404 Kbps
    Channel(s) : 6 channels
    Channel positions : Front: L C R, Rear: L R, LFE
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 233 MiB (15%)
    I would hate to have to re-encode to another format and lose any quality. Leaving that as a last resort.
    Thanks In Advance
  2. I'm not sure about WD Live. I have 1st gen WD player for USB. I remuxed an .mkv as .mp4 leaving the audio as AC3 and it complained that it had unsupported audio track. I used AviDemux to Copy the video and only convert audio to AAC and it worked as long as I selected 128 stereo in audio options.
    You might try going the other way. Use AviDemux to output .mkv with Copy for Video and encode Audio to AC3. It's worth a try. Typically one hour videos only take about 12 minutes when I go from .mkv to .mp4.
    You can also try here:
    http://community.wdc.com/
    http://milesaheadsoftware.org/
    Fully enabled freeware for Windows PCs.
    Mar 2004
    San Diego, CA
    Thanks for the reply.
    I did some digging around and found that it may not be my receiver at all.
    Seems the latest FW is really bad and one thing it has done is mess with audio in a big way.
    Many are complaining that AAC was fine before the latest update so I'm going to try and do a rollback and see what happens.
    I do not know if I have any other video files with AAC that I played in the past without issue.
    EDIT:
    Ok I just looked through my WDTV LP and I found several files that have AAC audio that I have watched before and watched several times. So I know for a fact that they played on this unit.
    Looks like the latest FW jacked things up.
    Sorry to have found this to be a WDTV FW issue. Still nice to know I can change audio though if need be.
  4. FW generally makes me paranoid. Anything that is flash updatable should have an "undo" to put back the original undeletable code(and the undo itself should be undeletable.) If you get paperweight then you can't even update anymore, or is that a misimpression?
    I updated to the last FW release for gen1 since I was pretty much forced into it. The addition of idx/sub support was worth the risk.
