Results 1 to 9 of 9
  1. Hi,
    The title kinda says it all. The bloggie camera produces side by side (SBS) HD Mp4 files that takes forever to render in Sony Vegas... The only editing done is crossfades between clips. I have found no way to have Vegas smart render these files
    Regards to you all!
    Oct 2005
    666th portal
    movie studio only smart renders dvd spec mpeg-2
  3. Member Cornucopia's Avatar
    Are from the FUTURE?
    Sony Vegas is currently only up to v10.e.
    Maybe that's why you're having so much trouble.
  4. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Also DV, HDV, XDCAM, HDCAM.
    No AVC yet.
    http://www.kiva.org/about
  5. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    corn - movie studio is always numbered 1 ahead of pro.
    eddv - are you sure studio does the others? i could only find reference to sd mpeg-2.
  6. Member edDV's Avatar
    Mar 2004
    DV for sure, HDV probably.
    Those guys in Madison try to dumb down the user interface for Movie Studio but the engine is similar across current versions. I'm amazed at what Movie Studio Platinum 10 can be coaxed to do but you need to be Vegas Pro savvy to see what is missing in the GUI.
  7. Hi,
    Sorry about the confusion. Yes indeed it is Vegas Movie studio 11 I was talking about. A friend of mine have pro 10d where I also tried but no smart render there either as far as I could try . The following is the specs from my source Bloggie 3D files:
    Format : MPEG-4
    Format profile : Sony PSP
    Codec ID : MSNV
    File size : 9.33 MiB
    Duration : 9s 9ms
    Overall bit rate : 8 690 Kbps
    Encoded date : UTC 2011-08-12 22:30:24
    Tagged date : UTC 2011-08-12 22:30:33
    Video
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Format settings, GOP : M=1, N=15
    Codec ID : avc1
    Duration : 9s 9ms
    Bit rate mode : Variable
    Bit rate : 8 355 Kbps
    Maximum bit rate : 16.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.134
    Stream size : 8.97 MiB (96%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 8s 85ms
    Bit rate mode : Constant
    Bit rate : 128 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 126 KiB (1%)
    All I want to do is to combine files in this format. Preferably I would like to cross fade with smart render of the the parts of the files that are not edited (cross faded). If this will not work I will have to do without crossfading. Will this work in Vegas movie studio or pro? If not, does anyone know of an alternative that will smart render? Re-rendering of these files definatly takes to long time in Vegas. Also it is nice not do degrade the quality of the video.
  8. Member edDV's Avatar
    Mar 2004
    No AVC Smart Render yet in Vegas (or anyone else that I know of).
    Vegas will re-recode all AVC even it you cut on I frames so go ahead with transitions.
    Other cutters will cut AVC on I frames (1/2 second edit accuracy) but I cant recall which.
    PS: Half second applies to camcorder (15/12 frame GOP) AVCHD, etc. Longer GOP AVC will have less accuracy.
  9. There is a buzz that Corel Video Studio can smart render. Perhaps still not 100%, there is o lot of variations of H.264 out there.
