I downloaded a couple Live FLV stream clips and certain parts of the video are jumpy/skipping for just a few secs and I have no problem using Avidemux or Avanti to convert these videos to MP4/MKV without audio (no need audio)...however I still see the few secs skipping/jumpy.
Is there anything I can do to improve or smooth out the jumpy/skipping part using filters? or other tools?
Original downloaded live stream clip:
Format : Flash Video (FLV1)
File size : 58.6 MiB
Duration : 20mn 48s
Overall bit rate : 394 Kbps
Video
Format : Sorenson Spark
Codec ID : 2
Duration : 20mn 48s
Bit rate : 372 Kbps
Width : 480 pixels
Height : 360 pixels
Display aspect ratio : 4:3
Frame rate mode : Variable
Bit depth : 8 bits
Stream size : 55.3 MiB (94%)
Results 1 to 1 of 1
best filters to fix upscaled video
By jamespoo in forum Video ConversionReplies: 1Last Post: 10th Mar 2012, 06:54 -
Avidemux 2.5.6 Failure to start on some videos where Filters are used.
By ABBrittain in forum Newbie / General discussionsReplies: 3Last Post: 28th Feb 2012, 10:47 -
How to fix avidemux error when h.264 is used
By skorpinok in forum Video ConversionReplies: 0Last Post: 15th Jul 2011, 10:00 -
How to add video filters effect without encoding with avidemux?
By tendra in forum EditingReplies: 2Last Post: 1st Nov 2009, 02:44 -
Any Simple Fix for Fraps or Xfire codec videos showing up green in avidemux
By ZZen in forum EditingReplies: 2Last Post: 6th Jun 2009, 13:51
