i am consdering these four
1.Philips Blu-ray Player (BDP3406)
2.Samsung Blu-ray Player (BD-D5300)
3.LG 360
4. Seiki BD660
any suggestion.
Results 1 to 11 of 11
Seiki BD660 because
1. it's the cheapest in the list (C$78 at Walmart)
2. it will play formats the others in the list balk at
3. its BD and DVD region code can be changed
4. it's hard to tell the difference between it and a Sony BDP-S360 playing the same blu-ray discFor the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i". -
According to the thread linked below, yes, it will play MKVs with AVC. For a problematic file you may need to run it through MKVtoolNix to fix the header:
https://forum.videohelp.com/threads/321596-Seiki-BD660-Wal-Mart-Canada-88!
If the picture quality is comparable to the Sony BDP-S360 (I have two of them), that's a pretty good recommendation.
I wonder, is this unit sold in the U.S. under a different name?Last edited by fritzi93; 25th Aug 2011 at 08:10.
Pull! Bang! Darn! -
I haven't tried MKV with it. In the Walmarts at Bolton, ON, and Mississauga, ON (Square 1) there are stacks of it in the electronics section. The price is currently C$78, which fell by some on certain bargain days like last boxing day (couldn't remember how much). It loads BDs very fast and picture quality via HDMI projected with Panasonic PTAE4000 is hard to tell from a Sony S360 that is wont to load BDs turtle-like. Smaller than usual case doesn't get hot. I didn't miss the absence of a display on player itself. I'm aware of the brouhaha about BD region coding, Oppo, Momitsu, and sites like bluraymods.com that charge an arm and a leg for the privilege; the Seiki seems too good but it's true and I don't know until when some powers-that-be find out and/or Seiki capitulates to them and all this is gone
I have two LG's and they will play just about any format you could want:
CD / DVD / BR
MP3
AVI, MP4, MKV-HD (With AC3 and dts), DivX Plus-HD (with AAC 5.1)
Plus, it will read all of these files from an NTFS external harddrive. (No worries about large file sizes.)For the love of God, use hub/core labels on your Recordable Discs! -
I have the 650 and 630.
Only diff beteen the two is that the 650 will do netflix and other streaming.For the love of God, use hub/core labels on your Recordable Discs!
Can i burn avi/mp4/mkv etc to blu ray media and play it in a blu ray player
By brad350 in forum Newbie / General discussionsReplies: 10Last Post: 21st Apr 2012, 04:15 -
Buying advice - Should LCD TV or blu-ray DVD player have Wifi capability?
By coody in forum DVB / IPTVReplies: 2Last Post: 11th Dec 2010, 10:52 -
Buying a Blu-ray player... any suggestions?
By jtrinc in forum Newbie / General discussionsReplies: 4Last Post: 6th Sep 2010, 12:20 -
Will You Be Buying A Blu-ray Player This Year?
By MOVIEGEEK in forum DVD & Blu-ray PlayersReplies: 32Last Post: 16th Mar 2009, 01:06 -
Sharp BD-HP20U Blu-Ray player worth buying?
By ebenton in forum DVD & Blu-ray PlayersReplies: 11Last Post: 29th Mar 2008, 14:13
