Hello all.
I have a DVD, with 4 movies in the VIDEO_TS Folder.
I was hoping to make 4 different DVDs (that is 4 different VIDEO_TS Folders), with each DVD only having one Single title.
I thought it was going to be a simple matter of cutting and pasting. for example, one folder would have the VTS_01_0.BUP, VTS_01_0, VTS_01_1, another folder would have the VTS_02_0.BUP, VTS_02_0, etc etc
BUT that only worked for the first title, and for the rest it said "directory not found" when i tried to play in media player classic
I am a newbie, so sorry for asking dumb question and would appreciate details if not a hassle for u
thanks
One quite crude way to achive what you want would be:
1).. Merge all the .vob files in their correct order into a single .vob using something like VOBMerge
2).. Make 3 identical copies of the single .vob, naming each a title name of the 4 movies.
3).. Open each .vob file in turn in an editor (AVIDemux ?) & trim off the other movies.
4).. Save each trimmed movie as a seperate .mpg.
5).. Use something like FAVC or ConvertXToDVD to burn a DVD -
wow i cant believe the Baldrick replied to me, this is awesome, ur famous
so ur procedure worked like a charm, i actually posted a new question in ur "adding permanent subtitle guide"
pretty much i was able to do the process with no problem for years, one day i started getting the message
" ERROR: Ifo has more than one PGC: Unsupported
C:\path...\Remuxed|VTS_01_0.IFO:
for subtitle creator, and as hard as i tried to look for solution i was never able to find one,
u think u got time in ur busy schedule to help me?Last edited by Dogpoundz; 24th Aug 2011 at 20:46.
Editing DVD chapters into a single title
By matthewjohn23 in forum Authoring (DVD)Replies: 6Last Post: 20th Nov 2013, 23:24 -
Can title menu have active multiple thumbnails using CXtoD (using 1 title)?
By bobbyg in forum Authoring (DVD)Replies: 1Last Post: 26th May 2010, 09:32 -
How to get a DVD title into a single file
By Case in forum ffmpegX general discussionReplies: 5Last Post: 21st Apr 2009, 04:28 -
DVD main title to single file, with AC3/DTS
By knight76 in forum DVD RippingReplies: 5Last Post: 27th Feb 2009, 10:30 -
Multi Episode dvd's with single title, Ripping troubles
By Malicious in forum DVD RippingReplies: 11Last Post: 5th Aug 2008, 09:32
