  1. Have trouble deciding the optimal file size when i rip BDs to MKV or MP4 using handbrake (h264).
    I play this via my HTPC (1080p output capable) using Media Portal.
    My TV is Full HD Plasma and projector is HD Ready.
    My receiver is not capable of decoding DTS HD.
    The final result should play smoothly (no stutter) on my TV. obviously this would depend on lots of factors. but what should i know while encoding the file.
    Mar 2011
    Colombo
    I suggest, not file size but video bitrate.
    Because, bitrate changes from the movie length and all.
    so, select something around 9000Kbps and see
    Constant quality.
  4. But what would be the optimal file size if i wanted to get results like iv said. for e.g. if i have 95min video on bluray. if i had to convert that down using h264 what bitrate/file size should i be targeting.
    sorry to be a pain.
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    For 1080p around 8gb and 720p 4gb.
  6. I agree with Baldrick's first post. Every video is different. Using constant quality encoding assures you that you will always get the quality you want, exactly the right bitrate (and file size since file size = bitrate * running time) for the video being encoded. And it's faster since it can be done in a single pass.
    Look at the three videos in this post:
    https://forum.videohelp.com/threads/295672-A-problem-for-video-experts?p=1811057&viewfu...=1#post1811057
    They are Xvid, not h.264, but the issue is the same. Which file size is is "optimal"? How could you have known beforehand?
