  1. Anonymous
    Guest
    video source: gaming console through composite AV cable
    capture card: EasyCap DC60, only supports 4:3 aspect
    I am trying to capture 16:9 videos from source, but my capture card is cheap 20 bucks and the driver update is only available for the next version of this series.
    I remember when I view the video from preview pin, I can see video added with black bars from above and below so that the preview can show me the wide screen source video. but when I tried to capture the video, the actual video was recorded without the black bars and it forces 16:9 to 4:3 video, and I hate it. I know I can use later use resize filter to upscale the video, but information maybe lost from the resizing and I want to keep the video as true to source as possible before I edit it.
    can virtualdub force recording the wide screen signal with black bars above and below so that even though my capture card doesn't support it, I can bypass this limitation?
    I also remember there is a way to add in 16:9 aspect flag even though the video dimension was not wide screen, but I don't know how to do it in virtualdub either.
  2. Formerly 'vaporeon800' Brad's Avatar
    Apr 2001
    Vancouver, Canada
    You want it to record without black bars i.e. anamorphic. Otherwise you'll be losing tons of resolution and double-barring the footage when viewed on a 16:9 monitor.
    You can easily flag it if you're encoding after capturing.
