  1. Member MI6's Avatar
    Aug 2004
    MACEDONIA
    What's the difference between this two types of DVD's.
    Regards.
    QUALITY HAS A NAME
  2. Banned
    Freedonia
    This old article has a very lengthy explanation as to why the author feels that +R is superior to -R.
    http://www.myce.com/article/Why-DVDRW-is-superior-to-DVD-RW-203/
    You will need to read English at a nearly fluent level for this to be useful to you.
    In reality consumers have not found any real practical differences between DVD-R and DVD+R and most just buy whichever is cheaper at the time of purchase. However, I do feel strongly that DVD+RW is superior to DVD-RW and that DVD+R DL is superior to DVD-R DL. -RW and -R DL discs are more expensive because they are more difficult to produce and compatibility with old DVD players is better for +RW and +R DL discs, but newer players should be fine with any +R or -R disc.
  3. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    When I buy a pack I don't even check any more. I am more concerned with the brand name I am buying for quality. I never saw any difference in them at all.
    May 2007
    Do they even make DVD-R's anymore? I haven't seen any at Best Buy for a few months now. I have a set top DVD Recorder that uses the DVD-R for recording, but plays back BOTH + and - discs. I hope to heck that they still make DVD-R's.
  5. Member Cornucopia's Avatar
    Most post houses I know use mainly DVD-R for their mass duping, and if you buy them in bulk (cakebox 50's), they're quite easy to find. Always preferred -R to +R myself, but these days it seems to make NO DIFFERENCE.
  6. Banned
    Freedonia
    If you don't buy your discs online in the USA and Canada, the odds are huge that you're buying crap. Yes, DVD-Rs are still available. Verbatim and Taiyo Yuden both make them and they're easily obtainable. Sometimes they're even cheaper than DVD+R discs.
  7. Member cyflyer's Avatar
    May 2004
    London uk
    Uh-ha ! But there is a very significant difference I have found. There is a capacity difference between DVD-R and DVD+R. The DVD-R is a few megabyte or a few byte LARGER capacity than the DVD+R. I discovered that if you have a DVD-R filled to capacity, ie with a compressed movie, and you tried to backit up to a DVD+R, you got the message "there is insufficient space on disc..." . This is quite an important deficiency. I have therefore always stuck with DVD-R.
