Results 1 to 12 of 12
    Aug 2011
    London
    Hello everybody,
    I'm trying to convert a .vob file into an editable file .
    Whereas the conversion works fine for MPEG4 .AVI (either ffmpeg or mencoder), when I try to convert it to MPEG4 or XviD (both .MOV ffmpeg), which is the format I think would suit for me, the conversion last 1 second and nothing is converted...
    Can you help me??
    Thank you
    Aug 2011
    London
    The information box says: "Codec type mismatch for mapping #0.0 -> #0.0"
    Thank you
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    VOB2MPEG
    ....would be great if you were not on a Mac.
    Aug 2011
    London
    I imagine there has to be a solution even if on a Mac....
    Can you help me?
    Alessio
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Aug 2011
    London
    I've tried that one, but it tells me that I need the "mpeg2 codec" which is only buyable at apple store...
  7. I'm a MEGA Super Moderator Baldrick's Avatar
    Maybe Avidemux.
    But how did get this vob file? Ripped, downloaded, etc? You can try mediainfo and see if it's standard vob file with mpeg2 or mpeg1 video.
    Aug 2011
    London
    OK, thanks for letting me know about Mediainfo.
    These are the specifics of my file. Basically I need to edit it, convert it and send it to web.... So an application like Mpeg Streamclip would be fantastic... but, again, it tells me I have to buy the mpeg2 codec at apple:
    Complete name : /Users/Alessio/Desktop/VTS_01_3.VOB
    Format : MPEG-PS
    File size : 463 MiB
    Duration : 1mn 48s
    Overall bit rate : 35.7 Mbps
    Video
    Format : MPEG Video
    Format version : Version 2
    Format profile : Main@Main
    Format settings, BVOP : Yes
    Format settings, Matrix : Custom
    Format settings, GOP : M=3, N=12
    Duration : 1mn 48s
    Bit rate mode : Variable
    Bit rate : 34.7 Mbps
    Maximum bit rate : 7 000 Kbps
    Width : 720 pixels
    Height : 576 pixels
    Display aspect ratio : 4:3
    Frame rate : 25.000 fps
    Standard : PAL
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Interlaced
    Scan order : Top Field First
    Compression mode : Lossy
    Bits/(Pixel*Frame) : 3.350
    Stream size : 449 MiB (97%)
    Aug 2011
    London
  10. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    When you see this error, try this:
    Set the "Invert mapping" checkbox in the Audio tab. Then Encode again.
    (This applies only to conversions with ffmpeg, not mencoder.)
    Aug 2011
    London
    Thank you very much Case!!!!!!!!
    It worked!
    Are you one of the developers of the program?
    Bye
    Alessio
  12. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    No, I'm not a developer; just a user. The development credit goes to major.
