For some mkv files, I can't get subtitles to load in MPC-HC, but they load fine in VLC. But subtitles in most mkv files display fine. I'm not sure what the difference is between the files that work in MPC-HC and the ones that don't.
The subtitles don't work for these files when "Play => Subtitles => Enable" is checked (I have subtitles enabled by default).
They also don't work when I select the subtitles track from "Play => Filters => [File Path] => S: [English]."
And they don't work when I select the "S: English" track by right clicking the Haali media splitter icon in the system tray.
(I think for the mkv files that don't work, the "S: English" track is not selected when the files are opened, but the "S: English track" is selected for files that do work.)
After a lot of searching, I am at my wits end, and I'd appreciate any help. I have installed several codecs and filters that I don't really understand, and I think a configuration issue may be causing the problem. I have installed:
AC3 filter
CoreAVC
VobSub
Results 1 to 1 of 1
Batch method to convert subtitles embedded in mkv's
By invinciblegod in forum SubtitleReplies: 4Last Post: 9th Aug 2012, 02:11 -
External subs don't play correctly with Anime .mkv with embedded subs (.ass
By Reveur in forum Software PlayingReplies: 1Last Post: 8th Nov 2011, 03:20 -
How to remove embedded subtitles from mkv
By imars99 in forum SubtitleReplies: 9Last Post: 24th Aug 2011, 03:06 -
MPC failing to load subtitles on long movies?
By crossmr in forum SubtitleReplies: 3Last Post: 26th Feb 2011, 10:27 -
.mkv subtitles in MPC
By andreyi in forum SubtitleReplies: 2Last Post: 22nd Dec 2009, 16:05
