I have Vegas Movie Studio Platinum 8.0d(up-to-date) running on Win 7 x86-64.
I recently acquired a Panasonic HDC-TM700.
My video is shot in MPEG-4 AVC/H.264(AVCHD) | 1920x1080 | 60i | 17Mbps.
When I simply select(not open), one of these files, whether in the Explorer or in the Import dialogue, it immediately freezes the entire program.
The size of the files(.m2ts) doesn't seem to matter. Even files that are 25/50 MB will trigger the freeze.
Any ideas appreciated. Thank You.
Yes, re-wrapping is just copying the video & audio into a new transport stream container
The idea is to try the least destructive options before you move on to more destructive ones
If that doesn't work, you can transcode to a digital intermediate. Something like cineform . Cineform has a free version now, called "gopro cineform studio" ; the entry level "cineform neoscene" used to be ~$100 . Filesizes are large, but it's visually lossless. It makes editing "snappier". You will find that version of vegas very slow & sluggish to edit AVCHD, unless you have a very fast setup -
Vegas will sometimes appear to freeze while it's looking for a decoder, especially on a network share. Did you try waiting for it to actually come back to you?
Are you sure version 8 supports AVC/AAC? I think it does, and that it's Pro8 that doesn't, but I can't remember. Maybe you need Platinum?Last edited by budwzr; 23rd Aug 2011 at 00:49.
Sony Vegas - Time freeze doesn't work
By Reiden in forum EditingReplies: 0Last Post: 5th Feb 2012, 14:11 -
AVCHD 24 Mbps and Vegas Pro 9, 10
By shaema in forum EditingReplies: 5Last Post: 27th Jul 2011, 10:11 -
importing avchd in to vegas?
By liverlipsyyz in forum EditingReplies: 5Last Post: 25th Feb 2010, 16:59 -
Vegas Pro 9 get timecode from AVCHD
By flamadiddle in forum EditingReplies: 12Last Post: 6th Jan 2010, 16:40 -
Increase audio velocity in SONY VEGAS 7.0 and freeze a frame?
By qazwsx16 in forum EditingReplies: 9Last Post: 30th May 2007, 21:35
