I'm trying to get some video game trailers for Star Wars: The Old Republic to play on my PS3. They're in an MOV container with AVC video and ADPCM IMA4 audio.
I've tried using Avidemux to remux to an MP4 container using stream copy on the video and converting the audio to AAC. This produces an MP4 file that plays video just fine but there is no audio playback. The PS3 shows an AAC stream but has dashes for the bitrate. MediaInfo says there is only 1 channel AAC audio in the resulting file for some reason even though the original ADPCM IMA4 was 2 channel. I've tried forcing the audio to 2-channel stereo. The file then says it's 2-channel but still results in no audio playback.
I've also tried using Super to remux to MP4 and convert the audio to AAC. This gives me a file that hangs for about 20 seconds when I first play it. It eventually plays only audio which is slightly stuttering but no video. It shows the video stream at 1kbps. Strangely the video DOES appear on the thumbnail.
Here is the link to the file: http://www.swtor.com/media/trailers/armor-progression
(just click the downward arrow at the bottom of the playback window, then select the MOV file)
I just want the file to play properly directly from the PS3 HD with minimal conversion and loss of quality. Does anyone have any recommendations?
Here's what I see with MediaInfo from the original file:
Code:General CompleteName : BH_Armor_progression_EN_H264_V1.mov Format : MPEG-4 Format_Profile : QuickTime CodecID : qt FileSize/String : 58.7 MiB Duration/String : 1mn 51s OverallBitRate/String : 4 408 Kbps Encoded_Date : UTC 2010-06-08 23:17:05 Tagged_Date : UTC 2010-06-08 23:19:48 Encoded_Library/String : Apple QuickTime 7.6.6 com.apple.quicktime.player.movie : (Binary) Video ID/String : 2 Format : AVC Format/Info : Advanced Video Codec Format_Profile : Main@L3.1 Format_Settings_CABAC/String : No Format_Settings_RefFrames/String : 2 frames Format_Settings_GOP : M=2, N=24 CodecID : avc1 CodecID/Info : Advanced Video Coding Duration/String : 1mn 51s BitRate/String : 3 992 Kbps Width/String : 1 280 pixels Height/String : 720 pixels DisplayAspectRatio/String : 16:9 FrameRate_Mode/String : Constant FrameRate/String : 29.970 fps ColorSpace : YUV ChromaSubsampling : 4:2:0 BitDepth/String : 8 bits ScanType/String : Progressive Bits-(Pixel*Frame) : 0.145 StreamSize/String : 53.2 MiB (91%) Language/String : English Encoded_Date : UTC 2010-06-08 23:17:03 Tagged_Date : UTC 2010-06-08 23:19:48 Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID/String : 1 Format : ADPCM Format_Settings_Firm : IMA CodecID : ima4 Duration/String : 1mn 51s BitRate_Mode/String : Constant BitRate/String : 384 Kbps Channel(s)/String : 2 channels ChannelPositions : Front: L R SamplingRate/String : 48.0 KHz BitDepth/String : 16 bits StreamSize/String : 5.12 MiB (9%) Language/String : English Encoded_Date : UTC 2010-06-08 23:17:03 Tagged_Date : UTC 2010-06-08 23:19:48
Also, I apologize if I posted this in the wrong forum. I'm fairly certain this is an issue with the ADPCM IMA4 audio which needs converted so that's why posted here. Please move the thread if I am mistaken.
Hi
FFmpeg does the job OK.
Code:ffmpeg -i BH_Armor_progression_EN_H264_V1.mov -vcodec copy -acodec libfaac output.mp4
Code:General Complete name : output.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 54.1 MiB Duration : 1mn 51s Overall bit rate : 4 059 Kbps Encoded date : UTC 2010-06-08 00:00:00 Tagged date : UTC 2010-06-08 00:00:00 Writing application : Lavf53.9.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.1 Format settings, CABAC : No Format settings, ReFrames : 2 frames Format settings, GOP : M=2, N=24 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 1mn 51s Duration_LastFrame : -33ms Bit rate : 3 992 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.145 Stream size : 53.2 MiB (98%) Language : English Encoded date : UTC 2010-06-08 00:00:00 Tagged date : UTC 2010-06-08 00:00:00 Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177 Transfer characteristics : BT.709-5, BT.1361 Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 1mn 51s Bit rate mode : Variable Bit rate : 61.4 Kbps Maximum bit rate : 64.0 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 838 KiB (2%) Language : English Encoded date : UTC 2010-06-08 00:00:00 Tagged date : UTC 2010-06-08 00:00:00
Testing H264/AVC frame accurate editing (AVCHD/MOV/MP4/MKV)) of SolveigMM
By DmitryV in forum EditingReplies: 18Last Post: 3rd Mar 2026, 15:15 -
SolveigMM Video Splitter 3 Release. AVC/264, MOV, MKV, MP4 on board
By DmitryV in forum Latest Video NewsReplies: 0Last Post: 1st Feb 2012, 10:42 -
Patching a MOV-file from 50 to 25 FPS without frameloss & re-encode?
By Oneirophile in forum EditingReplies: 1Last Post: 11th Oct 2011, 06:29 -
Editing/converting MOV MPEG-4 AVC fies
By yurkyurk in forum Video ConversionReplies: 1Last Post: 23rd Jul 2011, 11:46 -
Can't find a good program to convert .mov/.mp4/H.264/AVC watever video clip
By Nintendo Fan in forum Video ConversionReplies: 8Last Post: 21st Jan 2009, 18:28
