My living room is 17' by 12'. Should I project onto the long wall or the short wall? Not sure where to put this question, so popped it in here![]()
Depends on the projector and the image size you desire. Your projector manual should give you some diagrams and info on projected size. Or you can try a site like Projector Central and use their calculator. http://www.projectorcentral.com/projection-calculator-pro.cfm My projector is about 21' from my screen and the screen is about 10' diagonally. You also have to take into account your seating distance from the screen. Also where you plan to mount your projector. I mounted on the wall as I have a ceiling fan and a chandelier blocking a ceiling mount position.
What have they done to Wall-E now??
By frankvw in forum DVD RippingReplies: 22Last Post: 15th Sep 2010, 04:56 -
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 18:08 -
New to video wall this
By Aries in forum Newbie / General discussionsReplies: 3Last Post: 24th Dec 2009, 12:55 -
Berlin Wall
By uno in forum Off topicReplies: 2Last Post: 9th Nov 2009, 03:56 -
Wires in the wall
By ahhaa in forum ComputerReplies: 6Last Post: 12th Mar 2008, 13:13
