i have some dvds that will play and some wont(on my tv). i dont understand why cause i use dvd flick on all the dvds i make.does anyone know what the problem could be?
				Results 1 to 10 of 10
	the audio is 0x0055 mpeg-1 layer 3 and the video is xvid iso mpeg-4. i dont know if these are what you ment.
	Doesn't your dvd player support avi divx/xvid? Then just burn the avi files on a cdr or dvdr.
 If not then try another dvd converter like avstodvd or freemake video converter. If they also fail try another dvdr media brand.
	If those are actually the requested specs of a VOB file then something is seriously wrong.
 As for the problem, given the absolute TREMENDOUS AMOUNT of information you have provided, I can definitively state that the problem is one of three things : 1. The original source is somehow F'd up. 2. The program is somehow F'd up. 3. YOU somehow F'd up.
 Narrowing that down will require more info, such as file types, parameters used in conversion program, specs on source, specs on VOB's (already requested, see #3 above), type of blanks used, pretty much all the info you left out of your first post.
 Did you try checking the log file from DVDFlick, or perhaps standing on a street corner and asking random passers-by?
 How about what EXACTLY happens with a disk that "won't play". Does it take its toys and run home, does the player say "no disk", playback stutters or is garbled, the disk won't fit in the tray, anything? Have you tried playing it on a computer? Have you tried spinning it on your finger and staring at it REALLY HARD?
	nelson37: lol that was good. i will try to get all the info that you said. im new to this so it might be tomorrow before i post cause i have to work soon. if you could look tomorrow to see what i found i would really appreciate it. thanks
	Obviously that's not true if you then say this:
 That wasn't run through DVDFlick and it's not a DVD. It doesn't contain DVD video or audio. Maybe if you made DVDs like you claimed earlier, you'd be able to play them in your DVD player.
  MKV DvdRip Xvid Downloads Play on WMP but wont play on my PVRBy dashas in forum Newbie / General discussionsReplies: 7Last Post: 25th May 2011, 06:15
  xp wont play movieBy natty in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2010, 13:26
  8x DL wont play in PS3By Onceler2 in forum MediaReplies: 3Last Post: 6th Aug 2009, 15:16
  JVC Wont Play New DVD's!By Raxxor in forum Newbie / General discussionsReplies: 2Last Post: 29th Dec 2008, 14:02
  LG DVB-T wont play DVD'sBy scdom in forum DVD & Blu-ray PlayersReplies: 1Last Post: 1st Oct 2008, 08:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Visit Homepage
				Visit Homepage
