hi all,
I'm trying to mux a raw h264 with a raw g711 audio file to mp4 container.
for that I'm converting the g711 audio stream to 'au' by adding the au header,
and then using the ffmpeg program:
the result is mp4 file with both video and audio streamsffmpeg -i audio.au -i video.h264 -strict experimental av.mp4
but the video is playing almost 3 times faster then the original h264 stream.
i know that the input raw stream is interlaced 25 fps 704x576.ffmpeg version N-31932-g41bf67d, Copyright (c) 2000-2011 the FFmpeg developers
built on Aug 16 2011 18:54:12 with gcc 4.6.1
configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-runtime-cpudetect --enable-avisynth --ena
ble-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --en
able-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --ena
ble-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
libavutil 51. 12. 0 / 51. 12. 0
libavcodec 53. 10. 0 / 53. 10. 0
libavformat 53. 7. 0 / 53. 7. 0
libavdevice 53. 3. 0 / 53. 3. 0
libavfilter 2. 31. 1 / 2. 31. 1
libswscale 2. 0. 0 / 2. 0. 0
libpostproc 51. 2. 0 / 51. 2. 0
[au @ 01ECB720] max_analyze_duration 5000000 reached at 5056000
[au @ 01ECB720] Estimating duration from bitrate, this may be inaccurate
Input #0, au, from 'audio.au':
Duration: N/A, bitrate: N/A
Stream #0.0: Audio: pcm_mulaw, 16000 Hz, 1 channels, s16, 128 kb/s
[h264 @ 01EC91A0] max_analyze_duration 5000000 reached at 5000000
[h264 @ 01EC91A0] Estimating duration from bitrate, this may be inaccurate
Seems stream 0 codec frame rate differs from container frame rate: 50.00 (50/1) -> 25.00 (50/2)
Input #1, h264, from 'video.h264':
Stream #1.0: Video: h264 (High), yuv420p, 704x576, 50 fps, 25 tbr, 1200k tbn, 50 tbc
[buffer @ 01EC9C20] w:704 h:576 pixfmt:yuv420p tb:1/1000000 sar:0/1 sws_param:
[mpeg4 @ 01FD1B40] removing common factors from framerate
Output #0, mp4, to 'av.mp4':
Metadata:
encoder : Lavf53.7.0
Stream #0.0: Video: mpeg4, yuv420p, 704x576, q=2-31, 200 kb/s, 25 tbn, 25 tbc
Stream #0.1: Audio: aac, 16000 Hz, 1 channels, s16, 64 kb/s
Stream mapping:
Stream #1.0 -> #0.0
Stream #0.0 -> #0.1
Press [q] to stop, [?] for help
frame= 165 fps= 86 q=23.9 Lsize= 492kB time=00:00:06.60 bitrate= 610.9kbits/s dup=0 drop=163
video:340kB audio:147kB global headers:0kB muxing overhead 1.000657%
does any one can help me to find the reason why the video stream is playing faster then it should be?
ran.
ffmpeg "sees" your video stream as 50FPS (it should be identifying it as 25FPS)
ffmpeg can have problems with interlaced streamsStream #1.0: Video: h264 (High), yuv420p, 704x576, 50 fps, 25 tbr, 1200k tbn, 50 tbc
You can try FFMBC, it seems to work better with interlaced streams
What is the source of the video? What was the original container? ffmpeg works better with video in container (there will be timestamps to read) . Also if the video was not flagged as "interlaced" then ffmpeg might read it as progressive -
i agree, unfortunately the container is not a known one, and i had to demux the h264 stream from it with a code i wrote.
note that playing the video.h264 on vlc player works great, and with the right playing speed.
is there a way to tweak that with ffmpeg or any other open source windows base prog? -
It might be a playback issue contributing as well. Interlaced AVC works best in transport stream (.m2ts, .ts, .mts) . MP4 might not be suitable
1st thing I would try is FFMBC, it handles interlaced avc better than FFMPEG.
Maybe you can try VLC to mux it ? not sure how
Even if you mux it with tsmuxer 1st (and if that is read correctly), then ffmpeg will have a better chance than raw avc input -
thanks for your suggestions,
1. ffmbc is linux base program.
2. couldn't make it with vlc either .
i can strip the time stamp from the original container.
is there any way i can place it in the raw h264 stream?
if so where and how?
here is the dump of a the h264 sync codes:
Code:00 00 00 01 27 64 00 1f ad 88 0e 43 98 20 e1 0c 29 0a 44 07 21 cc 10 70 86 14 85 22 03 90 e6 08 38 43 0a 42 90 c0 42 18 c2 1c 66 32 10 86 02 10 c6 10 e3 31 90 84 30 10 86 30 87 19 8c 84 22 02 11 98 ce 23 c2 9f 11 f8 8f e2 3f 11 f1 1e 33 88 c4 44 42 81 08 8c 47 11 e2 3e 4f c4 7f 27 e4 f8 8f 11 c4 64 88 b6 05 81 22 40 00 00 00 01 28 e9 08 3c b0 00 00 00 01 25 88 85 06 ff 94 01 a8 61 03 4f fc cb 24 5d 8e e7 f7 78 89 f7 ac 9a 16 cc b8 b9 25 70 45 5e a4 b3 0c 4f be 1d 11 f9 1a d3 8d e2 85 a3 5f d0 9e f7 5e 47 16 24 4e 7c 2f 08 0f bf d7 cf 1a 98 ea 57 5b 5f 9a 61 82 f6 62 48 d0 11 ea ad 00 4f 8b 3e a4 66 15 33 e5 14 8e b7 5e b2 9b 8b 42 b6 0b a9 9d d2 5f c9 4d 3e e1 06 99 f5 82 a5 07 94 55 3f 98 b7 4d fd 03 e4 14 1c ... 00 00 00 01 21 88 86 1b ff 94 01 82 40 3c 3f cc b2 47 36 e4 fd 88 49 06 67 aa 2f cc be 68 77 df d2 fd 93 7c b7 84 37 17 a0 2f 30 03 f6 0e 21 78 be 28 03 46 a6 7d 6e 3b 4f c8 44 5c a0 40 2e c2 92 a4 43 c3 20 d8 df 1b d7 e8 b4 6f d1 7b 20 ed 3b 19 6f a9 72 48 bf 4b da 19 1e 82 82 4e 91 7b 8d 18 7d 6a 4a 28 27 2e 62 35 a0 96 2e ec a8 15 7e a9 6c a8 86 04 df f3 71 dd 5e 07 e4 6e 12 89 b5 4a cb 7f 63 01 35 93
Need to batch (or queue) convert raw h264 file to mp4
By dukestravels07 in forum Newbie / General discussionsReplies: 10Last Post: 29th Mar 2015, 11:45 -
how to decode g711 raw stream?
By niror in forum AudioReplies: 5Last Post: 19th Oct 2012, 07:25 -
How to create .mp4 file by using raw .h264 and .aac files for JW Player
By hakkinen in forum Newbie / General discussionsReplies: 2Last Post: 10th Mar 2009, 20:49 -
What do I do with a raw .h264 file extracted from an .mp4 container?
By godfist314 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2008, 12:51 -
Raw H264 to AVI Under OS X?!?!?
By RAILheadDesign.com in forum MacReplies: 4Last Post: 1st Jun 2007, 10:29
