I had a .srt file which i added to a mkv file container using mkvmerge and Charset was set to default. And the file was muxed. The subtitles were working fine until this musical character
♪ was replaced with ♪ . The info is below
Here are the 2 subtitles before muxing and after muxing.Code:ID : 3 Format : UTF-8 Codec ID : S_TEXT/UTF8 Codec ID/Info : UTF-8 Plain Text Language : English
Code:341 00:31:05,655 --> 00:31:08,750 ♪ If you pal around with that Copper hound 342 00:31:08,825 --> 00:31:11,203 ♪ You'll wind up hangin' on the wall 343 00:31:11,286 --> 00:31:13,914 ♪ Keep your nose to the wind You'll keep your skin
Can anyone please tell me how can i get the musical note ♪ again and which encoding i must use i.e UTF-8 or any other.Code:341 00:31:05,655 --> 00:31:08,750 ♪ If you pal around with that Copper hound 342 00:31:08,825 --> 00:31:11,203 ♪ You'll wind up hangin' on the wall 343 00:31:11,286 --> 00:31:13,914 ♪ Keep your nose to the wind You'll keep your skin
Any help will be appreciated.
Thanks.
All those hyper smart subtitle creators tends to use Tahoma - just change to Arial or Verdana .
Problem adding subtitle in MKV
By burple in forum SubtitleReplies: 2Last Post: 7th Nov 2011, 10:34 -
Problem subtitle edit with MKV & MP4
By whitebeard in forum SubtitleReplies: 2Last Post: 19th Jun 2011, 08:45 -
Subtitle with MKV problem
By maccool111 in forum SubtitleReplies: 3Last Post: 19th Apr 2010, 04:37 -
MKV to AVI subtitle problem
By rock99 in forum Video ConversionReplies: 1Last Post: 5th Feb 2010, 06:45 -
MKV to AVI - Little problem with .ass subtitle
By Nadleeh in forum SubtitleReplies: 2Last Post: 11th Jan 2008, 07:18
