Hi,
Does changing frame rate from the source file during the conversion matter?
Suppose if the source file has a frame rate of 29.97 fps and the target file is converted with 30 fps or 25 fps what would be the impact in technical terms? (though goes unnoticed most of the time with naked eye)
Regards,
mts
To change frame rate you either increase/decrease the frame rate, duplicate/decimate frames or fields, or blend frames or fields. Most are easily visible to the naked eye.
Thanks indeed;
So if I translate it into simple English (as I understand). While converting a video file to another format, (a) increasing the frame rate (over the source file) would enhance the quality of output file (b) vice versa, and (c) no change means same quality.
Frame rate conversion help
By Og in forum Video ConversionReplies: 20Last Post: 8th Nov 2011, 09:56 -
Frame Rate Conversion
By roberto188 in forum Video ConversionReplies: 17Last Post: 5th Mar 2011, 10:11 -
Frame rate conversion for NTSC to PAL conversion?
By Trellis in forum EditingReplies: 33Last Post: 27th Jul 2010, 09:55 -
By Alexstarfire in forum Video ConversionReplies: 35Last Post: 22nd Aug 2007, 13:34 -
Frame rate conversion by changing frame count
By asmaa in forum Video ConversionReplies: 2Last Post: 1st Aug 2007, 10:15
