    Mar 2011
    India
    I have a PC with WIN XP SP2 and have 4GB flash drive which has two partitions with U3 system in one.It is infected with autorun.inf. When I tried to remove/delete/rename thro cmd command, I get the message "access denied". Can I get suggestions to get rid of that.
    Thanks.
Name:	access denied.jpg
    Oct 2005
    666th portal
    how about re-formatting it? or deleting the partitions and then formatting it.
  3. Member Cornucopia's Avatar
    It may not let you as long as the U3 is on there.
    What I'd do is:
    Get the utility U3 Launchpad Removal Tool
    Insert your Thumb drive, while holding down the [SHIFT] key to diable autorun
    Backup the files you want to keep
    Run the removal utility
    Repartition & Reformat (not-QUICK mode) the WHOLE drive
    That should take care of it.
  4. DECEASED
    Jun 2009
    Heaven
    And the next time, convince yourself to ALWAYS "disable autorun for all drives"
    http://www.google.com/search?num=30&hl=en&safe=off&complete=0&q=%22disable+autorun+for...22&btnG=Search
    Mar 2011
    India
    Thanks aedipuss.
    Cornucopia - Thanks a lot. BTW can you please let me know the method "Repartition & Reformat (not-QUICK mode) the WHOLE drive"
    El Heggunte - Thank you - I will try the methods suggested to disable autorun for all drives.
    Mar 2011
    India
    Cornucopia
    I followed what you said. Removed U3 Launch pad which itself gave an option to reformat. I did that.
    Wow, the autorun.inf virus has gone once for all. Great relief and now I feel free. I once again acknowledge your instant help. Now, I can use the entire 4GB as a thumb drive.
    El Heggunte
    I disabled autorun for all drives. Great Pleasure. I Thank one and all of you.
    FYI, autorun.inf isn't the virus.
    But it could link to one in a hidden folder.
    Mar 2011
    India
    Thanks for the information. Anyway, I got it removed.
