I'm trying to create FLV video from sequence of images with mencoder.
I use following command :AndCode:mencoder "mf://@D:\Video\list.txt" -vf scale=320:240 -mf type=jpg:fps=4 -of lavf -ovc lavc -lavcopts vcodec=flv:vbitrate=250:mbd=2:mv0:trell:v4mv:cbp:last_pred=3 -oac copy -o D:\Video\video.flvto fix metadata.Code:flvtool2 -UP video.flv
But when I'm embed video to the site scrubbing doesn't work.
Can anyone help?
Already solved.
If someone else has similar problem, for me it work's fine with "keyint=x" parameter. With this parameter key frame will be inserted each "x" frames.
	Also check out: http://yamdi.sourceforge.net/
 The scrubbing problem you experience is because many FLV encoders place the metadata at the end, many CLI programs are available to move the metadata to the START of the FLV, allowing the web player to scrub (given that you have a web player that properly supports such, if I remember correctly JW Player does a great job... http://www.longtailvideo.com/players/jw-flv-player/ )
 Andrew
  mencoder - combining flv file without sound - helpBy grissom in forum Video ConversionReplies: 1Last Post: 10th Aug 2011, 03:39
  Mencoder // ffmpeg flv file Audio-video sync problemBy krishnareddy in forum ffmpegX general discussionReplies: 5Last Post: 26th Apr 2009, 10:13
  Mux a FLV AVI + MP3 -> FLV with ffmpeg or mencoder?By Colmino in forum Video ConversionReplies: 9Last Post: 29th Mar 2008, 23:11
  FLV videos have with flvtool still no metadataBy maltePORN in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2008, 13:16
  FLV Metadata ProblemBy RobinDeanDotCom in forum ffmpegX general discussionReplies: 9Last Post: 4th Dec 2007, 09:51
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
