    Mar 2001
    radcliff
    i want to know how to cahnge settings to keep movie in wide screen instead of full screen when i record to cdr. kinda new please reply
  2. well....unless you want to distort the movie....you should try to keep the output and source aspect ratio the same....
    you should use dvd2avi to tell you the aspect ratio of the dvd...either 16:9 or 4:3....then you can input this into the source aspect ratio setting in tmpgenc under the advanced tab before you encode....
