Is someone able to comment on the below? I'm trying to get the possible conversion out of the blu-ray I'm just curious if the settings I used got me that. Below is mediainfo on the file. It's a 1080p mkv file where I used these settings in ripbot...
Audio FLAC + x-audio stream
Video - CRF 18
I would have expected a file size that was around twice of what it currently is - 8gb or so.
General
UniqueID/String : 181096512269036494369863810639116490134 (0x883DEB699D5E7FC9A6128BF565A1D596)
CompleteName : \\HOMESERVER\Videos\Movies\HD\Pixar Films\The Incredibles\The Incredibles.mkv
Format : Matroska
Format_Version : Version 2
FileSize/String : 4.61 GiB
Duration/String : 1h 55mn
OverallBitRate/String : 5 714 Kbps
Movie : 00389
Encoded_Date : UTC 2011-08-21 03:57:16
Encoded_Application : mkvmerge v4.6.0 ('Still Crazy After All These Years') built on Mar 10 2011 02:50:32
Encoded_Library/String : libebml v1.2.0 + libmatroska v1.1.0
Video
ID/String : 1
Format : AVC
Format_Profile : High@L4.0
Format_Settings_CABAC/String : Yes
Format_Settings_RefFrames/String : 3 frames
CodecID : V_MPEG4/ISO/AVC
BitRate_Mode/String : Variable
BitRate_Maximum/String : 25.0 Mbps
Width/String : 1 920 pixels
Height/String : 1 080 pixels
DisplayAspectRatio/String : 16:9
FrameRate/String : 23.976 fps
ColorSpace : YUV
ChromaSubsampling : 4:2:0
BitDepth/String : 8 bits
ScanType/String : Progressive
Encoded_Library/String : x264 core 114 r1924 08d04a4
Encoded_Library_Settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=3 / b_pyramid=0 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=240 / keyint_min=24 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=18.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / vbv_maxrate=25000 / vbv_bufsize=25000 / crf_max=0.0 / nal_hrd=vbr / ip_ratio=1.40 / aq=1:1.00
Audio
ID/String : 2
Format : FLAC
Format/Info : Free Lossless Audio Codec
CodecID : A_FLAC
Channel(s)/String : 6 channels
SamplingRate/String : 48.0 KHz
BitDepth/String : 16 bits
Encoded_Library/String : libFLAC 1.2.1 (UTC 2007-09-17)
Language/String : English
The Incredibles is animation with great sound, but still it's a cartoon. You're using more than twice the size that I find necessary for animation. Frankly, even 720p is overkill. For a challenging reference encode try an original film source like the The Searchers or FMJ.
PS
I use MEGUI. -
Cartoons are alot easier to compress than normal movies.I would have expected a file size that was around twice of what it currently is - 8gb or so.
Sure you're not limiting it to size=SL-DVD? eg 4.6gb approx ....
cartoons ARE alot easier to compress than normal movies.Corned beef is now made to a higher standard than at any time in history.
The electronic components of the power part adopted a lot of Rubycons.
how to rip a blu-ray movie to a blu-ray disc
By TURBOLENCIA in forum Blu-ray RippingReplies: 1Last Post: 25th Nov 2010, 17:40 -
xvid4psp, encoding settings suggestions please, blu-ray-> blu-ray
By runLoganrun in forum Video ConversionReplies: 4Last Post: 16th Jan 2009, 09:07 -
Can i use a blu-ray reader to Rip my Blu-rays ?
By fairwind in forum Newbie / General discussionsReplies: 4Last Post: 29th Nov 2008, 12:04 -
can i use a blu-ray reader to rip my blu-rays?
By fairwind in forum DVD & Blu-ray WritersReplies: 2Last Post: 28th Nov 2008, 14:08 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
