  1. Hi, I have file captured by virtual vcr from Basler's camera. I want to convert this video to other format. Here is info from MediaInfo:
    General
    Complete name : F:\mis\recources\micexp\bowens 9 lite.avi
    Format : AVI
    File size : 102 MiB
    Duration : 1s 635ms
    Overall bit rate : 521 Mbps
    Video
    Format : BYGB
    Codec ID : BYGB
    Duration : 1s 635ms
    Bit rate : 520 Mbps
    Width : 640 pixels
    Height : 480 pixels
    Display aspect ratio : 4:3
    Frame rate : 211.604 fps
    Bits/(Pixel*Frame) : 8.001
    Stream size : 101 MiB (100%)
    Any suggestion ?
    Oct 2005
    666th portal
    in the video tab of virtual vcr did you forget to set the compression type? never heard of bygb but it looks like it might be some form of uncompressed video.
    try again?
