I'm having a problem that just started happening.
When I load a video file into MKVExtract GUI 1.6.4.1
it fails to give me any options for extracting video or audio.
It only shows "Chapters".
Can anyone help me figure out why? This happens on EVERY MKV file now, and it didn't have issues in the past. occurs on all files I've tried recently; from 40 meg to 8.9 gig.
Can't figure out what is going wrong as up until just recently it worked fine.
Are you sure you're using the latest version of mkvtoolnix, installed to the same folder?
You might try using MKVExtractGUI-2 instead.If cameras add ten pounds, why would people want to eat them? -
Thanks. That works great! I have everything updated and in the correct folders. MKVE2 that you suggest works now just fine. MKVEGUI doesn't at all. Though I'm interested in finding out what the issue is/was; with a working problem I'm not going out of my way anymore.
Many, many thanks!
JR -
Did you update mkvtoolnix in the time frame before MKVExtractGUI stopped working? It's possible the more recent versions of mkvtoolnix aren't exactly completely compatible with the original MKVExtractGUI.
I haven't tested it, though, so I can't be sure (while I do have MKVExtractGUI installed, I've been using MKVExtractGUI-2 for quite a while... and I think I don't have the latest version of mkvtoolnix installed, either.)
I probably did. I'm not sure what happened but I'm just happy to have solved the issue. Many thanks again for the help.
Follow the posted steps above.
MKVExtractGUI-2 worked great. Fixed my problems on MKV, MP4, OGM, and a few others, supports more formats, and even properly identified non-standard files in containers (like PNG, BMP, and even a Doom WAD file in an MP4 video about a new doom level)!. -
thankx, i just tried it with mkv, works great. I'll b so happy if its working with other formats also
Subtitle can't find with MKVextract & MKVtoolnix
By sanlocrip in forum SubtitleReplies: 2Last Post: 18th Mar 2012, 12:27 -
mkvtoolnix split problem with LG BD370
By paul_b in forum DVD & Blu-ray PlayersReplies: 4Last Post: 22nd Mar 2011, 08:59 -
MKVToolNix problem
By RosyIvory in forum Video ConversionReplies: 14Last Post: 8th Feb 2011, 21:46 -
Problem with MKVextract GUI
By Deathknight in forum Newbie / General discussionsReplies: 1Last Post: 27th Aug 2010, 21:51 -
can't find mkvextract in mkvtoolnix
By scarlac in forum MacReplies: 1Last Post: 20th Apr 2010, 09:19
