    Aug 2011
    Denmark
    I have a lot of MTS files which I would like to cut out a part of without reencoding/rerendering the video.
    I usually do this on AVI files with VirtualDub and Direct Stream Copy.
    I found describtions that said that I could use DShowInputDriver to import MTS files into VirtualDub but it doesn't seem to work with my Panasonic MTS files
    Any suggestions on how to get it to work with VirtualDub and Panasonic MTS files?
    Are the ways to convert Panasonic MTS files into some AVI encoding without loosing quality and without getting much bigger files?
    Best Regards
    Bjerner
    No, it's not possible without loosing quality and not getting much bigger files.
    I would try edit with something else, maybe tssniper or videoredo.
    Aug 2011
    Denmark
    Thank you for your answer.
    Do you then know about a converter which can convert MTS files to AVI files without changing resolution and being editable from VirtualDub afterwards?
