I'm making a website from my home videos. The videos are 1080p avchd and look great. I import them into Adobe premiere pro for editing and I have tried saving as 1080p and 720p. Both times I get some quality loss but it looks ok. Then I use adobe media encoder to turn them into flash files for the website, again losing quality. The 720p file size ends up being about 26mb per minute.
I understand losing quality but my concern is that I can go on youtube and find a hundred 1080p videos that look amazing that end up being about 25mb per minute. I'm losing significant quality and not getting any savings on the file size. If I'm going to have 25mb per minute video I'd love to have the quality and resolution of the 1080p. Or if I'm going to have lower video quality I'd like my file sizes to be much smaller. What am I doing wrong? What is the best process to maintain quality without having huge video files? Thanks
You didn't say exactly what you're shooting, what you're shooting with, and how. But handheld, shaky, noisy, interlaced camcorder video doesn't compress as well professionally shot film. Everything you can do to reduce noise and motion will reduce the bitrate requirement.
how "shaky" are your videos? did you use a stabilizer or tripod ?
how "noisy" are your video ? adequate lighting and exposure ?
These are the 2 most common variables that impair compression efficiency with "home videos"
Are you encoding from the original project or from the export ? (If you export from the original files, you will get better quality than if you exported a video then used AME in a second stage to export into flash flv) . Flash supports .mp4 so you can export that directly
Some people choose to use other encoders that are more efficient . x264 will give you better results than the mainconcept encoder from AME (either higher quality at the same filesize, or same quailty at lower filesize) . What you could do is export uncompressed then use a GUI x264 e.g. staxrip, megui, ripbot, handbrake, xvid4psp etc.... -
Thank you for the replies. I recently got married in Hawaii and wanted to post some videos. The camera was not used with a tripod, but in most cases the person with the camera wasn't moving either so they aren't really shaky. The camera is a panasonic HDC-TM60. The videos look quite good in the original avchd format, they are mostly outdoor in bright light.
I'm not really expecting them to look like professionally shot film, I'm more just trying to find the best way to get quality per filesize.
I will be sure to try what you suggested, I'm guessing it will help at least some. I'll let you know if it works better.
How to get the least loss of video quality when recoding MKV file
By dave in or in forum Video ConversionReplies: 13Last Post: 20th Oct 2015, 22:09 -
Compress large FLV file to a smaller size FLV file
By RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 17:21 -
encoding .VOB to .FLV with least loss in quality
By altavistasf in forum Video ConversionReplies: 9Last Post: 15th Oct 2010, 17:33 -
Can I get VOB to smaller file size with no loss of quality?
By Joolz2020 in forum Newbie / General discussionsReplies: 17Last Post: 23rd Aug 2010, 13:11 -
Best Video Format/Codec For Small Size, Yet Low Loss In Quality?
By kiwisoup in forum Video ConversionReplies: 13Last Post: 27th Jul 2010, 10:01
