Results 1 to 13 of 13
    gold coast, australia
    hey guys
    i used to use orbit but since changing to chrome it no longer works..on IE & chrome. the preferences have been changed but nothing works
    anyway i need to find a way of capturing some youtube footage and converting it to mp3 to listen on my ipod
    is this possible? if so is there a free and easy way of doing it?
    cheers
  2. Try Freemake Video Converter and Freemake Video Downloader.
    More details here: http://www.freemake.com/
    Dec 2006
    Here,where do you think?
    This works pretty darn good..
    http://www.youtubedownloadersite.com/
    " Who needs Google, my wife knows everything"
  4. Originally Posted by t0nee1 View Post
    I second this nomination, just make sure to NOT install all the ad-sponsored crap.
    TIP: use the medium setting when converting to MP3.
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    You can also try grabbing the YouTube video with a normal downloader, then using FLV Extract on it (if it's an FLV, of course... I don't remember whether or not FLV Extract works for MP4s downloaded from YouTube, or if you can simply demux those using a regular MP4 demuxer, like MP4Box) to extract the audio stream. Once you have the audio stream, you can convert it to whatever format you want.
    thanks guys, will try that one out
    also, anyone know why since changing to chrome, orbit wont work on either IE or chrome?
    usually, when a video file was on and the mouse went over it a download icon would appear, now nothing
  7. I still have Orbit 2.7.4 installed as all later versions, for me, wouldn't work properly - I use Orbit for grabbing images, so that I don't have to 'right click>save', plus swf files and occasional videos. Keeping my Orbit preferences the same, no other version after 2.7.4 would "grab" jpg's, bmp, png etc...
  8. For all firefox..chrome and safari users..you can use the youtube plugin which works great
    http://www.video2mp3.net/it/firefox_addon.php
  9. Originally Posted by angryassdrummer View Post
    My guess is Orbit isn't compatible with newer versions of Flash player, Chrome automatically updates the Flash player.
    it was working fine till i changed from IE to chrome, didnt work at all with chrome even tho i ticked it in preferences
    now when i go back to ie it doesnt work either, have tried reinstalling etc
    very frustrating as i used orbit a lot for a lot of streaming sites, youtube works well with the program recommended in this thread but other sites no
    is there any other free program that works like orbit, being able to download to hard drive video from any streaming site?
  12. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    If you switch to Firefox I got a super star utility that I use all the time, never failed yet.
  13. Originally Posted by Soixante View Post
    thats the one im using. you will get a button beneath every youtube video that lets you download it to mp3
