So, in other words it would not be a process that would be beneficial to getting done in a short period of time. Get home at ten after the game, capture game into computer. Do some editing of game, render, go to DVD Arch., put in menu, burn to DVD and usually get done by 3 am. or a little later. It would take me a lot longer than that I suppose doing the other steps involved int the process. There you go again, edDV, shooting me down again.![]()
Results 31 to 60 of 140
So, if I did not use AVIsynth what would happen? Would the quality still be better than a standard DVD? Would rendering times be slow? Not ever using anything but SD is my biggest concern right now. I would like the quality of HD though.
Is there a camera out there that has as good of low light sensors as the canon g10? What is the HV40 like for low light? My main concern is video quality and not sound. When it comes to the highlight video at the end of the year I usually dub in music anyway so sound really does not matter. -
It comes down to your quality threshold and whether you want an HD encode..
If you record 1080 60p or 60i and use a 60p or 60i timeline, you normally want to encode a 1080 edit master. Then you would encode a downsized 480i DVD MPeg2 version. That is a two step encode.
If you don't intend to save an HD edit master, you can just do the downsized 480i DVD MPeg2 encode in Vegas.
Alternately for better quality you could frame serve 1080 60i or 1080 60p to AVISynth, set up a script to downsize and encode to 480i DVD MPeg2 there. The encode time would be approximately similar to doing it in Vegas. You just need to think through your work flow needs.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
What would you do if you wanted good quality but needed to get it done quickly?
The conversion of 1080 60i or 60p to 480i in Vegas will be lossy during motion. Shooting 1080 60p should get better results but I've not tested it with 1080 60p AVCHD source. For 1080 60i the first step in Vegas is a blend or interpolated deinterlace to 1080 30p. This causes motion artifacts. Then Vegas downsizes to 480p and then interlaces to 480i MPeg2 for DVD. The result has motion at a 30 fps rate.
If instead you shoot 480i, your 480i DVD result will have motion at a 60 field per second rate (i.e smoother with less artifacts). The AVISynth 1080i/p->480i process will also result in a 60 field per second motion DVD result.
The g10 will be better for low light than the HV40. It benefits from the new signal processing. Better low light performance means less noise and better digital processing. If you are shooting night games, the g10 has advantage.
Sound issues are mostly about getting external mics to work correctly. For that you need the external mic jack, headphone jack, meters and ideally manual level controls.Recommends: Kiva.org - Loans that change lives.
For HD I'd get the G10, run it 60p and hope the Vegas DVD result is adequate. If not it can be improved by frame serving to AVJSynth. Downside is HD to DVD is going to take longer to process/encode. To speed things up, you should invest in that i7 CPU. You may also need to upgrade Vegas Pro to v10 or hold out for v11.
The HDV alternative allows you to capture 16:9 480i from the camcorder and edit/encode 480i. The IEEE-1394 capture process is realtime (1 hour takes 1 hour to capture) but 480i processing/encoding will be faster.
Correction: Just noticed the G10 doesn't have a 60p mode so that may throw the balance back to the Panasonic TM900.Last edited by edDV; 24th Aug 2011 at 15:13.
New gunslinger in town, the Sony HDR_CX700V that does 60p but doesn't cut it for noise or low light.
http://www.camcorderinfo.com/content/Sony-HDR-CX700V-Camcorder-Review.htm
http://www.bhphotovideo.com/c/product/748433-REG/Sony_HDR_CX700V_HDR_CX700V_HD_Flash_Memory.html
Back to the Panasonic TM900
Keep in mind I'm calling it for the TM900 on the theory that 1080 60p will convert better to 480 60i DVD in Vegas. That is your prime objective.
For pure HD work, I'd prefer the Canon G10 because of low light performance.Last edited by edDV; 24th Aug 2011 at 15:11.
Would the Sony HVR-HD1000 Professional HDV Camcorder be a better camera than the HV40? If not, I wonder if there is one like the 1000 that has a bigger sensor.
I am almost stuck right now at what to get.
Is there anyway I would not have to use AVIsynth as it will just not work fast enough for my time constraints if I use AVCHD?
You have a way of making me feel so stupid. Actually I am just jealous because of how knowledgeable you are about this stuff. I hate bugging people so much but I guess this is part of the education process. Having smart people educate us dummies.
So you think the TM900 would be the best way to go. Have you used the HV40 in any lower light situations? Now remember it won't be dark, it will be dark outside but lights on the field give off a decent light but still not bright.
Can you tell I just want it as easy and fast as possible. I also just want a good high quality video to use for the highlights at the end of the year. I am sooooo confused my head hurts. -
I have a Sony HVR-Z1U (3CCD prosumer) and a Canon HV20. The Z1U is better in low light but the HV20 does OK in good light like you describe. If you turn the camera to the crowd you will see a big difference.
The current equivalent to the Z1U is the HVR-V1U or the HDR-FX7 (less audio features but enough). both use 3x CMOS sensors (Better than HVR HD-1000 single CMOS)
http://www.bhphotovideo.com/c/product/459129-REG/Sony_HDRFX7_HDR_FX7_3CMOS_HDV_1080i.html
http://www.bhphotovideo.com/c/product/461818-REG/Sony_HVRV1U_HVR_V1U_HDV_Camcorder.html
The AVISynth process would work better for 1080 60i vs Vegas. If you shoot 60p, Vegas may be good enough for 1080 60p to 480 60i DVD conversion.Last edited by edDV; 24th Aug 2011 at 15:38.
Lets put it this way, if you primarily want a fast SD DVD workflow, but with an HD camera master, then a prosumer HDV cam like the FX7 or similar used model would allow in camera down conversion for a 16:9 480i DV capture. Then you could fast edit and encode a 480i DVD. The camera tape will be 1440x1080 60i HDV. The HV40 can do the same thing but with reduced camera performance and 1/3 the price.
The TM900 in 60p mode would allow a 1080 60p edit with conversion at the end to 480i DVD. Speed of processing depends on CPU speed.
Two ways to a similar result. Can't say if the DVD quality would be better either way without testing.Recommends: Kiva.org - Loans that change lives.
Right now I can do a 60 minute render of SD in 40 minutes. Quad core 6600 right now. Are there some used ones on B&H that you would recommend?
With an i7, that would drop to 20-30min.
Sony semi pro HDV camcorders had this history. Used camcorder buying is tricky. Best to shop locally with Craigslist and check it out thoroughly before purchase. Most of these camcorders have hours of use meters.
HDR-FX1 3x1/3" CCD (pro version Z1U)
http://www.ebay.com/sch/i.html?_from=R40&_trksid=p5197.m570.l1313&_nkw=Sony+HDR-Fx1&_s...All-Categories
HDR-FX1000 3x1/3" CMOS
http://shop.ebay.com/i.html?_nkw=sony+hdr-fx1000&_sacat=0&_odkw=Sony+HDR-Fx&_osacat=0&....c0.m270.l1311
HDR-FX7 3x1/4" CMOS (pro version V1U)
http://shop.ebay.com/i.html?_nkw=sony+hdr-fx7&_sacat=0&_odkw=sony+hdr-fx1000&_osacat=0....c0.m270.l1313Last edited by edDV; 25th Aug 2011 at 01:40.
Yeah, I will be building the i7 in a couple of months. Just waiting for the right size SSD to go on sale that I want.
I don't know what to do now. The canon G10 seems to be the best fit for lighting but no 60p. The panny900 is good for this but AVCHD. The SonyHVR-HD 1000 has too small of a sensor. The Canon HV40 also has smaller sensor. What would work best for light is not best for rendering and time constraints. In order to get the best of both I would need to spend how much?
Vegas Pro 10/11 will help for AVCHD but v9 is fine for HDV/DV.
Expect Vegas Pro v11 to be optimized for AVCHD 2.0 including 1920x1080 60P support.Recommends: Kiva.org - Loans that change lives.
So, I could end up getting the Panny 900 with AVCHD and it would work fine? Or some other more expensive AVCHD cam?
I don't have a TM900 to test a 60p to DVD 60i convert. Maybe someone else can try that in Vegas Pro or Premiere Pro (both use Mainconcept codec but could vary in downsize method).
If you go the AVCHD route, you should keep up with Vegas upgrades.
More expensive AVCHD cams (NXCAM or AVCCAM) will have more features but the same consumer codec. Most are not yet AVCHD v2.0 ready. That means 1080 60p not yet supported.Recommends: Kiva.org - Loans that change lives.
So, then I would be better off going the other route and not going with and SD card camcorders and going with mini dv style like th HV40 but only better quality. I am so messed up, what would you recommend after the HV40? I think you may have told me earlier but I have breathed since then and my mind is scrambled. I have no problem going with a mini dv camcorder.
You are at a fork in the road.
1. Tried and true HDV with SD or HD workflow (that new FX7 or HV40 from B&P if you don't want to hassle used). You can skip the computer and Vegas upgrade. You are fine for DV/HDV.
2. Join the AVCHD v2.0 cutting edge with the TM900** (i7 CPU and Vegas Pro 11 recommended*).
You need to make a decision.
* v9 Vegas will get you started.
** the TM900 is not AVCHD v2.0 certified. Since Vegas is now owned by Sony, they may stiff Panasonic on this point. They are like cats and dogs.Last edited by edDV; 24th Aug 2011 at 18:26.
If I would go for the FX7 what could I expect? I will have to order online. I see a place that has a good price and good reviews and under 1700 for a new one. How does it work compared to the HV40?
Be careful to check the user ratings for an online retailer. If the new price gets too distant from B&H get more data.
Read the reviews and make sure you understand the pros and cons of the product.
Sony markets two versions of their prosumer camcorders. The main difference is the audio support. The FX series is sold online and in Sony retailers. It has a simple omnidirectional stereo mic and an external stereo mini jack for an external microphone system. The pro version (HDR-V1U) is sold through pro retailers and has a shotgun mic, individual audio channel level controls and balanced XLR pro mic jacks.
The FX7 came out around 2007 at a $3500 price but is still available. It is a solid workhorse. These reviews seem fair. Look at others. The Canon XH-A1 and HDR-V1U still sell for around $2800. The FX7 has dropped to around $1999.
http://reviews.cnet.com/digital-camcorders/sony-handycam-hdr-fx7/4505-6500_7-32065017-...ml?tag=rvwBody
http://www.camcorderinfo.com/content/Sony-HDR-FX7-Camcorder-Review.htmLast edited by edDV; 25th Aug 2011 at 02:28.
I wonder if it's possible to borrow one or the other. You really won't know how well they work in your situation until you try it.
You can download raw videos from any camcorder on-line and try them in your NLE to find out how quickly (and well) then can be edited to SD.
Just a thought: (H)DV transfers in real time - how much faster/slower are the 28MBps 1080p60 files? I'd assume at least 4x faster (never tried it myself, but it's just a HDD>HDD or SD>HDD copy). I don't know how much footage you shoot and ingest, and whether you absolute want to watch it all while copying in real time anyway.
Cheers,
David. -
Sometimes reviewers post some. Sometimes just googling the camcorder model and raw footage will work.
Some people upload raw video to vimeo, especially when the camcorder is first released - if you register you can download the raw video at the bottom right of the screen if it was uploaded during the last week. After that the raw version gets removed (unless the uploader was a premium user).
So search vimeo for the model number of the camcorder.
Cheers,
David.
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 19:35 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 14:42 -
ExpressCard / 34 slot vs Firewire 800
By Sjogogo in forum MacReplies: 4Last Post: 6th Dec 2010, 01:54 -
HD Cam wrote .mts files to my flash card but put in another cam still mts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 15th Dec 2009, 07:15 -
FireWire 800 unecessary for DV editing...BUT...
By Gromit137 in forum Newbie / General discussionsReplies: 4Last Post: 22nd Dec 2008, 09:05
