if a file is already an mpeg do i still have to convert it with TMPGEnc?
thanks for any help.![]()
Depends on what you want to do with this MPEG file. If all you want to do is view it on your computer, then probably no you do not have to convert. But if you want to make a VCD or SVCD, then you may or may not have to convert. Things such as which flavor of MPEG, resolution, bitrate, framerate come to mind as to what you may want to check to see if you are close to the standards for either VCD or SVCD.
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Is there any free reliable tool to convert the .mov to MEPG?
By coody in forum Video ConversionReplies: 1Last Post: 12th Dec 2008, 21:05 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
making movie from many mepg/vob files
By volam in forum EditingReplies: 3Last Post: 10th Apr 2008, 11:33
