  1. Hey,
    1-2 years ago i was capturing some old video tapes and ran into a problem and i couldn't figur this out even after hours of searching on google.
    Today i decided that i will fix this problem but i guess i need an expert on this.
    Many frames have this weird "distortion" and it looks like this:
    http://www.pic-upload.de/view-11106004/Unbenannt.jpg.html
    http://www.pic-upload.de/view-11105982/Frame4.jpg.html
    Its as if something is dragging several frames to the right or left.
    How can i fix this? I used an external tv card probably made by Pinnacle
    Thanks for reading
  2. Member edDV's Avatar
    Mar 2004
    Northern California, USA
    Originally Posted by A2K View Post
    Hey,
    Thanks for reading
    Need to recapture from original tapes ideally through a TBC.
    http://www.kiva.org/about
  3. Well thanks edDV. Are your sure a TBC will be able to fix this? I mean if I am going to spend some money on this, it really needs to resolve this. I also want to add that when I hook up my camera to a TV those "distortions" do not happen.
    I was thinking about buying a new DVD Player, so might aswell buy a DVD Recorder with a TBC. Would that kind of TBC be enough. Can you recommend a good DVD Recorder with TBC?
    Also are there any other opinions on this matter? I really need to be sure a TBC will fix this before i make that kind of Investment.
    BTW how do call this kind of problem? Time Base Error? Couldn't find threads with Google that are centered around the same problem.
  4. Member edDV's Avatar
    Mar 2004
    First try a different player, then a different capture device.
    The problem is extreme tape tension skew cased by a faulty player or sticky tapes. Or a faulty capture device.
    If this is only one or a few tapes, take it to a pro dub house with money back guarantee..
