  1. Member jhv's Avatar
    Aug 2011
    Honduras, C.A.
    Hello, I´m John from Honduras and having problems with dvd-player Mastertech-265 reproducing videos from cd. Format video VOB. The result looks like a slow-motion picture. Reproducing the same video from my USB everything works fine. Somebody can tell me what this problem is about? Your response will be very much appreciated. Sorry for my bad english!
  2. Banned
    Freedonia
    "Reproducing" is not the correct word in English. Do you mean "playing"? We need a lot more information to help you.
    1) VOB is a DVD format but you say you are playing from CD. Is this on a CD disc? Or is it on a DVD disc but you said the wrong thing?
    2) Who made the discs you are using? (ie. Sony, Verbatim, Ritek, etc.) What type are they? (DVD-R, CD-RW, etc.)
    3) What did you do to make the discs? List all the software you used to convert to DVD format and burn the disc.
