hi all
im having a issue here
i want to edit parts of a movie out
1.got the anydvd HD trial and ripped my movie out
there was one large M2ts file so i got that and tried to import it into sony vegas pro 10
"the file could not be opened"
google it a bit and found people with the same issue but no help
so i thought why not use ripbot264 and change it to MKV so i can edit it
vegas cant work with MKV
so then i got why not use tsMuxer and change the container to TS
(vlc worked with it normally)
so i used tssniper and gave me an error on both TS and M2ts
so then i tried tsdoctor and worked (m2ts) but it was very hard to work with almost impossible
so i thought i might have some luck removing the container :P and using the vc-1 and the audio file separately but sony dosnt like vc-1 either ......
maybe i did something wrong when i ripped the movie with anydvd
any help ?
EDIT: one thing i noticed vlc dosnt give me " time " i mean for example the movie is 1:50 hr long vlc shows 00:00 but MPC shows the correct value
another thing is that TS doctor PES on video stream detected "this could be problematic" (save value yes/no)
				Results 1 to 12 of 12
	I would guess a decoder/splitter problem.
 VLC uses internal decoders, hence it worked; tsSniper needs Haali and ffdshow, hence it did not work.
 Try installing ffdshow, v.3382 and Haali splitter v.1.11.96.14. The correct versions available on the first post of this page:
 http://forum.doom9.org/showthread.php?t=143716
 In tsSniper settings, set preferred splitter to Haali AR.
 You should fill in your computer details so we don't have to guess. If you're using XP, install udfReader for good measure. I hope you don't have a codec pack installed.
 And welcome to the forum.
 [EDIT] Leave Haali configuration alone. In ffdshow Video Decoder Configuration, click Codecs upper left. In the Format column find H.264/AVC. Click the entry in the Decoder column and select ffmpeg-mt from the drop-down list. For VC-1, select WMV9. For MPEG2, select libmpeg2. Apply and close.Last edited by fritzi93; 19th Aug 2011 at 14:09. Pull! Bang! Darn!
	did what u said still didnt work
 the file being loaded does not contain a usable video track
	I haven't attempted this myself but have some global thoughts and I'll explain how I would approach the problem.
 First Vegas isn't intended for opening a Blu-Ray project. It does specifically support import of various camcorder formats including AVCHD m2ts import which is limited to one h.264 video stream at specific bit rates with AC3 stereo audio (PCM stereo for NXCAM).
 Blu-Ray m2ts includes multiple video and audio tracks (maybe two dozen tracks total) plus captions and other data.
 Second, they may actually block anything that looks like Blu-Ray m2ts.
 First I would demux the blu-Ray m2ts and isolate the video and audio tracks of interest. Start with video only and see if that loads into Vegas. Most Blu-Ray discs are 24p so match the project setting to the source format.
 Second determine the audio format and convert it to an audio format Vegas will accept such as multitrack PCM or AC3 2.0 or 5.1.
 If that doesn't work you can convert bit rates and/or frame rates to match a supported camcorder format such as AVCHD or NXCAM.Last edited by edDV; 19th Aug 2011 at 17:04. Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	I missed that it was VC-1. Was assuming h.264 or MPeg2. Recommends: Kiva.org - Loans that change lives.
	I downloaded the sample you linked to in the PM you sent me. (You'd be well advised in future to let everyone see any relevant information, the chances someone can put his finger on your problem will be better).
 MediaInfo doesn't show anything wrong with your clip, and it plays in MPCHC. (And I should have told you that tsSniper won't accept VC-1 or DTS. You need to first convert to AVC or MPEG2 for the video, and AC3 for the audio).
 [EDIT] Yes, it's VC-1 and DTS-HD.
 Anyway, my earlier suggestions were not entirely useless. You're now properly configured to use BDRB and other Blu-Ray to Blu-Ray programs.  Last edited by fritzi93; 19th Aug 2011 at 20:00. Pull! Bang! Darn!
	maybe try multiavchd --
	You can use BDRB, it will convert the video to AVC (H,264), and the audio to AC3 640 kps unless you tell it not to in settings. The target size must be smaller than the original to force a re-encode, taking into account the fact that re-encoding from DTS-HD or True-HD will in itself save at least several GBs of space.
 Then tsSniper will be able to load the *.m2ts file in the STREAM folder. I have done this from time to time, and you need to take care not to push the program too hard, or it will crash. (Seeking the file will be slowish, when jumping ahead/back don't do anything else until it completes seeking, a couple seconds at least). More often, I edit *.ts captures at considerably lower bitrates.
 But you should know that H.264 is difficult to edit, and AFAIK, the only freeware able to do a reasonable job of it is tsSniper. (Good enough, with practice, to edit out commercials from HD-PVR captures.) It's not frame accurate, cutting on key frames only. Maybe one of the pay programs can do better, I dunno, not having tried any.
 Maybe it would be better for you to just cut with tsMuxer. Watch the video with MPCHC or whatever and note down the in and out times.
 Anything so highly compressed is bound to be rather difficult to edit. Most members here who do much editing do it uncompressed or in lossless format of some type. Home theater hobbyists generally don't bother trying to edit much, except for captures.
 Can we ask why you need to do this?Last edited by fritzi93; 21st Aug 2011 at 17:53. Pull! Bang! Darn!
	its strange
 i noticed that the ONLY program out there that can edit(cut) parts out of a movie and keep the DTS-HD - True HD track without changing it is tsMuxer even vegas studio HD platinium cant do that
 tsmuxer is a pain to work with because i need frame by frame editing
 and going back and forth with MPC is tiresome
 i guess ill have to settle with freemake video converter its the only program i found that can edit movies convert the audio and video all in one go
 if you know any software that can edit videos and keep the true HD etc intact please let me know ill pay to dollar for it
 and for your question well there is a movie i have and its one of those movies that start at the end then ends at the start
 its like one of those mystery movies
 and what i want to try is " fix it "
 and see how it feels
 i did it with freemake video the movies felt a lot more "wow"
 but ac3 felts lacking not because it had low kbps or what ever it was because if i bitstream trueHD to my yamaha 671 receiver ,the reciever "knows" what to do everything sounds a thousand times better basically surround is perfected
 thank you for your time and help
 peace
  Cap Card Editing Issue?By Evas1on in forum Capturing and VCRReplies: 7Last Post: 7th Jan 2010, 12:25
  Avidemux editing causing audio sync issueBy perdomot in forum EditingReplies: 0Last Post: 14th Sep 2009, 16:29
  Sound delay issue after MPEG2 editing (avidemux)By dodoecchi in forum Video ConversionReplies: 8Last Post: 22nd Mar 2009, 06:55
  Resident Evil First movie ...Not Apocalypse the 2nd movie backup issue!!!By vanc in forum DVD RippingReplies: 0Last Post: 19th Oct 2007, 12:33
  Using Blueray or HD , Converting or EditingBy Fary4u in forum Newbie / General discussionsReplies: 1Last Post: 13th May 2007, 17:42
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
