Currently I'm using AVStoDVD 2.4.1 to backup a DVD9 movie to DVD5, using the build-in HCenc encoder. The source is as follows:The result should be a DVD5 movie with 1 audio & subtitle track. However, the subtitle is not processed and not present.
- VIDEO_TS folder on HD (in which I select the .ifo from the biggest .vob chain)
- The movie includes:
- 1 audiotrack
- 1 subtitle
So, I was wondering if AVStoDVD can process subtitles directly from the DVD source (and I mean without manually adding them as txt, srt or any other supported file format). Is this possible?
I don't think so. But you can use DVD Rebuilder, it also uses hcenc.
No, it can't. As Baldrick said, the proper tool to be used is DVD Rebuilder to get best quality. Another good choice is DVD Shrink (easier, faster but may give lower quality when compression gets under 80%).
Bye -
Thanks a lot for the swift reply guys... I'll give DVD Rebuilder a try.
BTW, I was very pleased with the ease of use of AVStoDVD. Maybe the processing of subtitles directly from DVD source is a feature that can be included in a future release
AVStoDVD Subtitle Preference
By FrozenInferno in forum Authoring (DVD)Replies: 8Last Post: 8th May 2011, 18:48 -
AVStoDVD Audio sync (m2ts source)
By newbtube in forum Video ConversionReplies: 10Last Post: 5th May 2011, 23:57 -
AVStoDVD audio out of sync from TS source
By nazopo in forum DVD RippingReplies: 3Last Post: 20th Dec 2010, 23:02 -
AVStoDVD srt Subtitle Problem
By adyf in forum SubtitleReplies: 15Last Post: 6th Dec 2010, 14:27 -
AVStoDVD Subtitle
By bebado22 in forum Video ConversionReplies: 6Last Post: 22nd Oct 2010, 06:26
